Results 1 to 7 of 7
    Toronto
    latest issue...95 200 Xri EFI sudden random bog
    serial 0G145336
    This motor is running almost perfect with the DETO and IDLE Stabilizer boxes removed.
    It starts up with barely a turn of the key!
    This issue I still have it random shutting off sort of thing.
    It will do it at any RPM...running up onto plane at 3000ish rpm and a quick bog, I stop and it idles perfect, so go again, might do it, might not, then never again all day.
    OR, cruising at 4500 rpm, and it's like it's shut off for a split second...then keeps going. It even did it a couple times at 5600 rpm.
    Any ideas?
    Plugs look great.
    Thanks
    Toronto
    just want to add to this, from some reading here...my main harness plug's lock ring is broken...I will zip tie it shut tight tonight. Maybe, or maybe not the problem?!
    Jul 2002
    FT WORTH, TEXAS
    fuel pump driver intermittent maybe
    Toronto
    I have the fuel pump wire to a good ground and the positive to the purple wires on the bakelite strip....
    Jul 2002
    FT WORTH, TEXAS
    good how about the filter that was in the u shaped supply hose below the pump it been removed ??/
    Toronto
    Quote Originally Posted by TEXAS20225 View Post
    Keep going! I appreciate your help on this.
    Let me then say, all the filters, cone shaped U hose one, the disk at the top, the spin on, all fuel lines, primer bulb, mechanical pump kit, etc were replaced! That cone filter was the worst!
    Toronto
    Ohm tests on the switch box wires from the stator all checked out good too....motor charges at 14.7V's at times (as per digital BassCat dash).
  1. Sudden loss of control box power
    By HighOctane in forum Technical Discussion
    Last Post: 10-07-2014, 07:46 PM
  2. Mercury Tech: Old Merc Laser 220 noisy all of a sudden (exhaust reliefs?)
    By gmacrae in forum Technical Discussion
    Last Post: 07-11-2014, 11:25 PM
  3. Sudden compression drop in #4 cyl
    By 71V153 in forum Technical Discussion
    Last Post: 06-25-2013, 07:07 PM
  4. sudden loss of power on 300x
    By kingmate in forum Technical Discussion
    Last Post: 05-17-2007, 10:15 AM
  5. Replies: 64
    Last Post: 03-22-2006, 04:55 PM
