Results 1 to 1 of 1
Thread: LF250 Not Charging
05-05-2016, 02:41 PM #1
LF250 Not Charging
Have a LF250TXR that is not charging. Checked the following
Stator output peak voltage test: spec is 44.7 @ 1500 RPM, mine tested at 45.00
Stator OHM test: Spec is .1144-.1716, mine is .000
Rectifier test: Spec is 13V @150 0 RPM, mine is 0-.5V
I changed the rectifier but there was no change. Has anyone seen these stators pass a voltage test but not an OHM test
Thx
Mercury Tech: 280 Alt not charging
By stanton in forum Technical DiscussionReplies: 5Last Post: 10-15-2009, 01:04 PM -
Mercury Tech: Charging??? 2.4 225
By CKMATE225 in forum Technical DiscussionReplies: 7Last Post: 09-25-2009, 05:58 AM -
charging
By jphydrostream in forum Technical DiscussionReplies: 5Last Post: 10-22-2005, 05:27 AM -
charging sys. ?
By daytrader in forum Technical DiscussionReplies: 3Last Post: 06-05-2004, 09:07 PM
