Results 1 to 15 of 32
Thread: 300xs spark plug problems
05-04-2016, 01:00 PM #1Member
- Nov 2015
- Ky
- 77
Got an 2014 300xs, at about 20 hours #4 plug came out and 3 other plugs were about to fall out, only held in with a few threads. Dealer checked the plug holes and put new plugs back in and torqued them like the service manual says to. Now at about 80 hours #4 plus came back out. Should I push for the dealer to replace the head? What would cause this? Thanks
05-04-2016, 01:25 PM #2Screaming And Flying!
- 14,703
- 380
- 1280
- 5599
- 10936
Never had a plug back out of the head even with 150#'s compression.
05-04-2016, 01:54 PM #3
I would have them look for the real problem. The only times I have ever seen spark plugs come loose was due to detonation.
05-04-2016, 02:06 PM #4Screaming And Flying!
- 14,703
- 380
- 1280
- 5599
- 10936
How does detonation cause plugs to come out? Not doubting, just curious.....
05-04-2016, 03:01 PM #5
THats got to be the strangest thing ive ever heard of it almost ssounds impossible.
05-04-2016, 04:03 PM #6
I don't know, maybe start here if you're really interested: http://www.dynotechresearch.com/blog...nYear=2008#212
05-04-2016, 04:24 PM #7Screaming And Flying!
- 14,703
- 380
- 1280
- 5599
- 10936
Wow, that is a cool read. Thanks for the info. Who would have thought it could happen?
Chad r, what do the plugs look like when they have come out? New heads at the very least would be my request from merc. I am going to see my bud who is a merc tech in the am, I will ask if he has seen or knows about this....
05-04-2016, 05:03 PM #8Member
- Nov 2015
- Ky
- 77
05-05-2016, 10:00 AM #9Screaming And Flying!
- 14,703
- 380
- 1280
- 5599
- 10936
Just talked with my tech bud. Never seen this happen with his 10+ yrs of merc repairs. Threads are stripped or plugs not installed properly was his only answer. A ddt should show a fault if the computer has detected detonation...
05-05-2016, 10:34 AM #10
But more likely, it's NOT detecting it or not at a low enough level; which would be why the plugs are backing out.
The sensitivity of the knock sensor depends (partly) on how tightly it's screwed into the block... if it's not tight enough it won't be as sensitive (but the sensor could be bad, too).
If it was knocking badly it probably would have come apart by now.
05-05-2016, 10:46 AM #11Screaming And Flying!
- 14,703
- 380
- 1280
- 5599
- 10936
Sounds like it's time for some contact with the merc tech line for the OP. Or his dealer/tech.
05-05-2016, 12:46 PM #125000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
I don't think 300xs has knock sensor.
05-05-2016, 12:57 PM #13
05-05-2016, 01:12 PM #14
I'm curious, how do they manage to have independent knock control for each cylinder without a knock sensor?
The new Propulsion Control Module (PCM) 07 microprocessor features a fuel calibration unique to the 300XS. The calibration, combined with the race-bred combustion chamber design, results in the engine producing peak power for a longer period of time at the upper rpm operating range. The PCM 07 optimizes fuel, spark timing and knock control for each cylinder independently, enhancing engine running quality and performance.
Dave_r liked this post
05-05-2016, 04:42 PM #15
no knock sensor or sensors on 300xs.
Spark plug 245?
By pickwickangler in forum Technical DiscussionReplies: 18Last Post: 07-02-2018, 09:20 PM -
Another 300XS spark plug question.
By ALE in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 4Last Post: 04-24-2013, 01:04 PM -
Any problems using automotive spark plug wires on an outboard?
By gdp in forum Technical DiscussionReplies: 1Last Post: 04-23-2013, 09:56 AM -
2007 300XS spark plug question.
By ALE in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 14Last Post: 04-17-2013, 02:06 PM -
98 300 drag spark plug problems
By JSB in forum Technical DiscussionReplies: 1Last Post: 04-24-2005, 05:17 AM
