Results 1 to 8 of 8
05-03-2016, 07:34 AM #1
Electrolysis potential ? Unorthodox use of Rub-Rail
Hey guys -
So while installing my amplifiers and speakers for the boat, I had an idea from my automotive background... Instead of running a ground wire through the whole boat harness.... Can I just use the Aluminum Rub Rail as a ground return? Would that potentially cause electrolysis on the rub rail?
My rubrail is nut & bolted in, not riveted. I can put an electrical lug on the inside of the boat up front under the dash, and use the rub rail to travel to the rear, back to the battery, with another jumper.
Anyone else done something like this? Can you think of any issues? The rub rail doesn't sit in the water, which is what normally causes electrolysis, right? Boat doesn't sit in water, always trailered. Rarely will ever be in Salt.
05-03-2016, 01:05 PM #2
Speaker doesn't work with just one wire; no real reason not to use paired conductors.
05-03-2016, 01:44 PM #3
05-03-2016, 01:52 PM #4
I would be more worried about how good the electrical connection between the bolts and the rubrail is... even with stainless bolts in aluminum "The corrosion of the base metal is marginally increased by the fastener." https://www.fastenal.com/content/fed...0Corrosion.pdf
It can be frustrating chasing a bad ground when something doesn't work right.
05-03-2016, 02:20 PM #5
David, That's a really good read. I wonder if putting the direct current of an 800 watt amp grounding through the stainless bolt would exacerbate the corrosion.
I guess if I lose the ground, I can always move 6" to the next fastener on the rubrail haha.
I love science threads like this. Anyone else have experience?
05-04-2016, 04:23 PM #65000 RPM
- Apr 2005
- Canada, East!
- 518
- 10
- 11
- 304
- 50
- 2 Thread(s)
800 Watt DC amp and your thinking of using the rub rail as ground?
Likely not a good idea. No science involved.
pointer
dondante liked this post
05-04-2016, 04:34 PM #7
I have always believed that if ya gonna run 1 wire....why not run 2? I even run ground wires for automotive and trailer electrical connections and have zero problems. Gary
05-04-2016, 05:25 PM #8
Many things are grounded to the frame. In my shop I use the conduit as ground and right or wrong it works. I would do some testing with a voltmeter and see if it will zero out. I do believe a separate ground wire is best but don't see why the aluminum rail won't work.
RockTeam Junk
OMC Rail ? 2 stroke v8 sand rail?
By 40hpmariner in forum General Boating DiscussionReplies: 12Last Post: 01-26-2011, 10:37 AM -
Potential?
By mercman1984 in forum Props, Setup, and RiggingReplies: 3Last Post: 07-06-2010, 09:01 PM -
Potential of a 94' 150 Promax
By yanny_haulinbass in forum Technical DiscussionReplies: 1Last Post: 07-19-2007, 07:02 PM -
Hey All You Potential Sob's Take A Look
By 2.5-21 in forum General Boating DiscussionReplies: 1Last Post: 12-06-2003, 02:33 PM
