Results 1 to 15 of 23
05-01-2016, 05:58 PM #1Junior Member
- Mar 2016
- marquette mi. 49855
- 20
1980 140 hp. L6 crank,rod,piston-assy drop into 1978 150 hp. L6? yes-no?
would a 1980 140hp. L6 crank-rod-piston assy. drop into a 1978 L6 150hp.? thanks
smako78
05-01-2016, 07:01 PM #2Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,273
- 215
- 30
- 581
Drop in,yes...correct,no.The Pistons in the 140 don't have boost ports,the 150 does...So,it will fit but performance will suffer,Chris
05-01-2016, 07:19 PM #3Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Is compression and port height the same other the the boost ports, can you port the 140 pistons to match?
05-01-2016, 07:43 PM #4Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,273
- 215
- 30
- 581
Not sure when the high dome piston was superceded by the low dome,mid 70's I'm guessing.The Pistons without the boost ports may have the reinforcement ring around the boost port area,if yes then you could port your Pistons and all should be good.If no reinforcement I don't know how they'll hold up.
FMP thanked for this post
05-02-2016, 06:31 AM #5Junior Member
- Mar 2016
- 20
thanks for your reply
05-02-2016, 06:41 AM #6Junior Member
- Mar 2016
- 20
my 78 150hp. s.n. is 475- with 622-# old style rod this 140hp has power ports on the starboard side with 624# new style rods. there both low dome! What's different the port Size? or where the port is drilled?
05-02-2016, 06:48 AM #7Junior Member
- Mar 2016
- 20
So if displacement bore stroke is the same. How is it a 150hp. in1978 and 140hp. in 1980-81?
05-02-2016, 07:42 AM #8Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Marketing to fit the 140 segment and then say that Merc has the best.
05-02-2016, 08:29 AM #9Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,273
- 215
- 30
- 581
Ok,sorry,my mistake regarding the 140.Yours(1980) is the same as the 150...I was thinking of the first 140 Merc sold in 1972 that had no boost ports.Your 1980 140 is really a re-decaled 150...since Merc offered a detuned v6 175 as a 150 at that time they decided to call the inline a 140...later it even dropped to 115 at the prop,it is considerably less powerful than the v6....sorry to mislead,Chris
Mark75H liked this post
05-02-2016, 09:15 AM #10Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Even 115 at prop was a understatement for market share.
smako78 thanked for this post
05-02-2016, 09:21 AM #11Junior Member
- Mar 2016
- 20
So I just bought a 1980-81? 140hp. crank,rod and piston assy. it was listed 1982 140hp. for parts. I'm going to use the 3 best piston in the 1978 150hp. because I haven't used her in 20 years ( very low hours ) I don't think Merc. made a 1982 140hp.?
Hopefully in a couple a weeks I'll be fishing Lake Superior Lake Trout out of Big bay Mich. P.S. to everyone I rebuilt this 26 years ago so Change your impeller pump every 4 YEARS Steve.
05-02-2016, 10:08 AM #12Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I think last year. Lakers , can't be too deep yet, riggers or divers . No kicker , troll the L6 or big jigs with white grub ?
05-02-2016, 01:17 PM #13Junior Member
- Mar 2016
- 20
I have to drag a bucket or drift sock behind to get 1.6-2m.p.h. for south shore trout! Would you power port all 6 pistons? Does it help fuel economy ? Stay low dome stock and use 91 octane? With 87 octane I'd burn 3 to 3.5 gals. per hour at 28 knots. Calm to 3 foot choppy water. So again power port? yes/no
05-02-2016, 03:45 PM #14Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I can't imagine using the L6 for trolling , build her like the boost port 150 and she would used a bit more fuel I suspect . 3.5 / hr is good at cruise .At one time guys were machining the block and milling the case so the crank center line would be closer to the deck giving more compression .That would give a bit more power without the extra fuel but you would need to find the hands on knowlegde for the amount and what to do with the ports. Find a 4 stoke 9.9 and hang that on the side , troll the whole day for $5. Now that I think about it , us said big water, might want a bit more than a 9.9 just to fight the wind.
05-04-2016, 02:14 PM #15Junior Member
- Mar 2016
- 20
I guess I'll end this post. I'm staying with a all stock ''78'' 150 hp. If any one wants to mod. your old Merc. type Harry r. Brinkman pdf. There's 88 pages of GOOD STUFF
Remember !!! a bad day of Fishin is better than a good day at Work!!!
1978 mercury 1400 piston ring install
By atomant in forum Technical DiscussionReplies: 5Last Post: 02-12-2016, 11:18 PM -
15" clamp assy.. Drag Piston!!
By mark4608 in forum Misc. Parts and AccessoriesReplies: 6Last Post: 12-12-2015, 06:23 PM -
OMC Tech: 1978 175HP Lower crank seal
By numlaar in forum Technical DiscussionReplies: 4Last Post: 07-16-2013, 04:27 PM -
1978 140hp mercury inline six lower unit, will it fit on 1980 175 2.0?
By mrice0406 in forum Technical DiscussionReplies: 6Last Post: 01-20-2008, 05:30 PM -
1978 Johnson Stinger vs. mid 1980 Johnson's
By fairbanks 1977 in forum Outboard and Racing HistoryReplies: 2Last Post: 08-04-2006, 06:40 PM
