Results 1 to 9 of 9
05-01-2016, 04:01 PM #1
Optimax 225 bogs to stop. Slow to restart. But once restarted runs fine to 4800.
2002 Optimax. Idle perfect at 550.. 13.8 v at fish finder on helm 12.3 shown engine off Batteries new. 3 new coils 3 new coil drivers
engine will run 5900 just against occasional guardian for rev limit for approx 45 seconds then slowly shut down to 4200. Not in Gaurdian mode. Pull throttle back it shuts down. Acts locked up.. 30 seconds later of sitting fires up and will run all day long if you keep it below 4000 rpm. Power is there acts like its electrical issue vs mechanical. Injectors haven't been touched yet. Pressures are 94/84 on air/ fuel. And compression cold prior to installing engine was 105 psi on all 6 warm was 130 on 5 125 on cyl 6
sounds like it it may have a reed valve going but that wouldn't cause the full shutdown of the motor at speed...
944 hrs but only 350 above 1100 rpm....
Im stumped... New to me motor haven't got the bugs out of it obviously... Ideas?
engine temp is 120 ish and just below thermostat temp.
Could it it be trying to cold seize.....Last edited by 150aintenuff; 05-01-2016 at 04:05 PM.
05-02-2016, 07:10 PM #2Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Is that compressor temp or actual engine temp? Smart craft reads the compressor temp.....120's is normal for compressor. My 2001 opti reads 140ish on the head temps.
05-03-2016, 02:14 PM #3
gauge temp from heads.. varified with heat gun on shut down.. heads show 115 degrees after 15 min run external temp smart craft shows 108 at compressor
if factory T stats are still in it Tstats should be 120... if updated 130... unknown.. havent pulled out yet..Last edited by 150aintenuff; 05-03-2016 at 02:16 PM.
05-03-2016, 02:19 PM #4
if its seizing its getting pulled down in 3 weeks and given a touch more clearances... and updated T stat temp... but if its electrical..... thats my biggest worry... is its a power issue.. because then the whole damn boat could be a factor.
took off a flawless 150 to run into this issue.. but optis are way power hungry vs a carb 2.0
05-03-2016, 02:21 PM #5
but it has 900 total hrs on it and this wasnt an issue before obviously...so something changed.....
05-03-2016, 07:00 PM #6
ok smart ass... that isnt helping
05-04-2016, 11:02 AM #75000 RPM
- May 2012
- tenn
- 219
- 12
- 17
Prop down and let er eat.
150aintenuff liked this post
05-04-2016, 08:16 PM #8
funny brian
05-24-2016, 04:28 PM #9
WELL HELL tore into it... Broken Reed, and Broken Ring land DAMN IT so beyond the fact it was still running perfectly this sucks... wasnt planning a rebuild yet.. oh well... time to OPTI XS it
anyone got XS fuel rails or regulator pressure springs???
V-rod. High idle. Runs fine no codes
By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 2Last Post: 07-20-2015, 10:11 PM -
OMC Tech: 115 evinrude ficht, starts fine when cold, no hot restart?
By rchevelle71 in forum Technical DiscussionReplies: 5Last Post: 06-19-2012, 12:14 PM -
OMC Tech: 2001 225 FICHT RAM runs great for 1/4 mile then bogs
By baja200merk in forum Technical DiscussionReplies: 6Last Post: 10-25-2010, 10:15 AM -
Mercury Tech: Optimax 150 runs fast and slow
By bakerfreak in forum Technical DiscussionReplies: 3Last Post: 09-13-2010, 08:26 AM -
Stop Or Slow Down
By mirage243 in forum The Scream And Fly LoungeReplies: 9Last Post: 12-10-2009, 11:48 AM
