Results 1 to 5 of 5
Thread: 225 opti low compression
04-28-2016, 05:52 PM #15000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
Buddy has a 225 opti and all cylinders only show 78#'s, cold, pulled heads no wear or marks in cylinders what's the deal?
04-28-2016, 05:55 PM #2Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
T body open, guage bad ?
04-28-2016, 08:49 PM #35000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
New Napa gauge, I wasn't there for the test, but assume since they work on outboards the tbody was open
04-29-2016, 09:24 AM #4
possible bad compressor. check air pressure on port side rail while cranking. should be 80psi or more.
04-29-2016, 12:01 PM #55000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
Okay will do, gotta see what I need to check it. Thanks, hope that's it cause I could pick it up cheap right now
Regular 225 Opti vs 250 Opti XS
By stingray240cs in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 9Last Post: 02-06-2018, 03:28 PM -
Dual Repower 225 opti, 225xs or 250xs/opti
By fishnchips in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 10Last Post: 02-18-2008, 08:18 PM -
225 Opti compression numbers and removing bottom plugs?
By Mr. Demeanor in forum Technical DiscussionReplies: 1Last Post: 04-24-2007, 11:07 AM -
Is these numbers on 225 Opti Compression ok?
By wildnphx in forum Technical DiscussionReplies: 6Last Post: 03-19-2007, 11:36 PM
