Results 1 to 12 of 12
Thread: Yamaha HPDI injectors
04-22-2016, 06:19 PM #1Junior Member
- Jan 2016
- Naples FL
- 29
I'm thinking about buying a boat that has a early 2000's VMAX 200 hpdi that's been sitting. It's running rough and I'm assuming the fuel system needs cleaned out. Are the injectors serviceable or should I consider replacements? I haven't checked injector prices, but I have a feeling it's gonna be expensive. I don't anything about these motors and I'm nervous about the deal.
04-22-2016, 06:56 PM #2
They can be flowed and cleaned if necessary
04-22-2016, 08:06 PM #3Junior Member
- Jan 2016
- Naples FL
- 29
After doing some more reading it looks like this motor is a potential nightmare full of filters and expensive pumps.
05-01-2016, 02:32 PM #4Markus' Performance Boating Links:
05-06-2016, 12:43 PM #5
HPDI pumps are an easy clean/ rebuild if needed.. YES THEY ARE SERVICABLE!!! contrary to what yamaha will tell you.. and the injectors and the 4 hidden bqasket filters are where issues can cause major engine failure.. clean and flow them and remove the filters within the HPDI pump and you wont have any issues.. DO ALL THE FILTERS!!! not just the main clear view filter.. there are like 15 filters total in them..
05-06-2016, 05:04 PM #6Junior Member
- Jan 2016
- Naples FL
- 29
I spent a lot of time studying everything and it's not bad. The motor is a 2002 2.6 200hp and I would rather pay a little more for the same boat that already has a 3.3 250 hpdi. Is there any reason to consider the 2.6 over the 3.3? The 200hp pushes it a little over 60 mph and that's not too bad for a fishing boat I guess. 70+ would be really fun though LOL
05-07-2016, 02:52 AM #7
i wouldnt expect 70+ maybe 68-70.. but its possible to get a stronger 250 HPDI.. and see more.. the 3.3's were finiky.. ive fixed 4X the 3.3's than i have the 2.6... FWIW
05-07-2016, 06:32 AM #8Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
05-07-2016, 09:15 AM #9
MAIN FILTER-- low pressure fuel pumps--VST filter--- mid pressure pump---- mid pressure inline filter--- High pressure pump--4 basket filters---fuel rails---6 basket filters in injectors
that the ones off top of my head... not to mention the 3 OIL line filters, one at back of tank, one at under cowl oil tank and one right before main oil piumpLast edited by 150aintenuff; 05-07-2016 at 09:18 AM.
05-09-2016, 12:46 AM #10Junior Member
- Jan 2016
- Naples FL
- 29
05-20-2016, 06:52 AM #115000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
05-24-2016, 06:17 PM #12
never had an issue with a 3.3 IF you do the injector pump filter elimination on them, they clog like CRAZY
250 HO E-Tec or 250 HPDI Yamaha
By Matthew Ward in forum General Boating DiscussionReplies: 7Last Post: 10-21-2009, 09:48 AM -
Yamaha 200 HPDI
By mrv8outboard in forum Technical DiscussionReplies: 25Last Post: 09-04-2009, 12:56 PM -
Yamaha HPDI
By Skirace87 in forum Technical DiscussionReplies: 21Last Post: 10-04-2007, 08:58 PM -
Pro's and Con's of Yamaha 300 Hpdi?
By frozenballs in forum Technical DiscussionReplies: 21Last Post: 01-17-2007, 05:15 PM -
yamaha 150 hpdi
By brian117 in forum Technical DiscussionReplies: 6Last Post: 07-11-2004, 01:50 PM
