Results 1 to 7 of 7
04-18-2016, 10:08 AM #1New Member
- Sep 2015
- Kentucky
1985 Johnson 140 cylinder head question
Will a 87-93Johnson 140 cylinder head pt #398818 work on my 1985 Johnson 140 ? Thanks in advance.
04-18-2016, 04:20 PM #2
Believe that's a looper head #. Is your '85 an Xflow or looper?
04-18-2016, 06:38 PM #3New Member
- Sep 2015
- Kentucky
Its a looper
04-19-2016, 06:02 PM #4Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
88 to 93 are a deeper chamber than what you have but could be milled to the same cc. 85-87 are small bore engines while 88 up are larger bore.
01-10-2017, 03:07 PM #5
01-10-2017, 06:25 PM #6
Well, raising compression, opening up the exhaust, re-jetting, etc. Are good places to start.
I would assume that motor is a looper. OMC didn't sell a 140 xflow in '85. It was detuned a lil to become the prop rated hp 115.'71 Glastron V153 - Composite rebuild - Unceremoniously wrecked
01-12-2017, 06:53 PM #7Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
You can start with either so long as you have a bore shop that can but a recess back into the sleeve at the bottom after boring to the larger displacement.
powerabout, AZMIDLYF liked this post
Johnson V8 cylinder head
By Phil Cartier in forum Technical DiscussionReplies: 18Last Post: 05-12-2013, 06:27 PM -
1985 Johnson GT150 Seal question
By towens35 in forum Technical DiscussionReplies: 4Last Post: 06-06-2006, 08:14 PM -
1985 115 johnson question
By Ronny Jetmore in forum Technical DiscussionReplies: 2Last Post: 09-25-2003, 05:25 PM
