Results 1 to 1 of 1
04-17-2016, 08:47 AM #1
1976 Evinrude 75 Hustler shortshaft
1976 Evinrude 75 shortshaft completely rebuilt top to bottom. Includes new CNC tilt and trim jackplate. The motor starts very easily. Break-in instructions are included. This motor was rebuilt to correct OMC specs by a very experienced OMC racing mechanic (the seller). New crankshaft, two new pistons (Sunnen-honed), new rings and rod bearings, new gaskets, seals and o-rings, carbs cleaned, new fuel lines and fuel pump. New swivel bracket bushing and seals, 2 new and 2 older good shock mounts. New driveshaft, new gears and clutch dog, new bearings (driveshaft shims set with an OMC shim gauge), new seals and impeller kit. Cylinder head milled .065". This motor was rebuilt to run correctly. I can have the motor crated in a new Evinrude crate for $100 with shipping to be arranged by the buyer.
$5500
I can build props for this motor for either v-bottom or tunnel. I have two new Booe 12 1/2x22 cleavers. I rework these props for SST60 Class and for folks with restored 13', 14' v-bottoms.Last edited by smokin'joe; 12-25-2016 at 11:01 AM.
1976 hydrostream hustler make over
By MERCURY#1 in forum Fiberglass and Composites DiscussionReplies: 8Last Post: 01-12-2014, 04:14 PM -
78 evinrude hustler 70hp
By goblin79 in forum Outboard and Racing HistoryReplies: 10Last Post: 01-27-2013, 10:31 AM -
Evinrude 75 hp Hustler
By whci in forum Technical DiscussionReplies: 1Last Post: 05-24-2011, 10:45 PM -
1976 Hustler 40HP Johnson Prop Selection?
By mn79vector in forum Props, Setup, and RiggingReplies: 2Last Post: 07-11-2006, 07:46 PM
