Results 1 to 5 of 5
    Jul 2014
    wisconsin
    PLEASE HELP 90 johnson gt200
    new to Johnson,new boat.can you over trim a motor. was hooking up muffs to run in driveway and the guy I bought boat from had the transom lever locked to hold motor,i raised motor closed bracket and motor wont trim down?goes up fine(have trimed vertical now and cant get to go down with trim switch)is the trim pump the little round part 2 wires in on the ram section to the left facing back of boat.is there a way to test it before replacing?power going to etc, how can I get the motor down manualy.thanks so much for any help.
    There is a manual release screw on the port side of mounting bracket,now tell me more about it not trimming down,is the tilt motor running,do you hear a clicking when you activate the trim down switch.maybe out could post pictures of what you think the trim motor is because it sounds like you are describing the trim sender.
    Jul 2014
    wisconsin
ID:	341632part looks like this.tilt motor works going up nothing on the down side(no buzzing,clicking)don't work going up on trim switch on motor or controls only down switch works.thanks.
    lindsay on. canada
    if the motor has 2 wires only and it works going up it will run going down , you have a trim solenoid problem most likely ,or the wires or switches .
    WI
    Prob a relay....where in WI are you??
    I have a boat or two.... that I never get to drive
  1. johnson gt200
    By XcellR8 in forum Technical Discussion
    Last Post: 04-24-2012, 08:43 AM
  2. OMC Tech: 1990 Johnson GT200 Low RPM's
    By prov1x in forum Technical Discussion
    Last Post: 07-31-2011, 04:11 AM
  3. johnson GT200 alarm
    By Richard in forum Technical Discussion
    Last Post: 07-23-2011, 08:10 PM
  4. Johnson GT200
    By Don's AE21 in forum Technical Discussion
    Last Post: 01-20-2010, 12:30 AM
  5. JOHNSON GT200 worth?
    By THEFERMANATOR in forum Technical Discussion
    Last Post: 10-26-2008, 03:59 PM
