Results 1 to 4 of 4
04-09-2016, 03:48 PM #1New Member
- Apr 2016
- texas
same question(prop) different new guy :)
Hello fellas, first off sorry for the long post and thank y'all in advance for taking time to read my post and give any thoughts.
my current setup:
boat :flats and bay 18x8(pad hull similar to a bass boat or well a flats boat)
motor :2000 Yamaha f115
prop: rapture(Michigan wheel) 13 1/4x15
factory manual jack plate with I would say about 6" offset
running cav/av plate about even with bottom of hull maybe a bit higher( at work can't be exact right now)
dry weight is listed as a light 900lbs
dead rise unknown
ok. so when I run it WOT I get to 6100 which I believe to be the rev limit on my motor and top speed is 40mph
when I run the numbers in a prop calculator I get less than 1% slip which is hard for me to believe but that's the numbers and the speed was confirmed by gps.
My question is what size prop do yall think I can step up to to get a higher top end. My ultimate goal is to get top end as high as possible so I can then cruise at around 40 without running WOT. I do sometimes run roundtrip 60+ miles in a day of fishing. >30 miles roundtrip without trying so I just wanna be able to cruise a bit faster. Right now I can cruise at 35mph at about 5600 I think.
The thing is I have been told by a prop guy that I will not be able to get much more or better than the 15"pitch(me and him disagree on what the rev limit on my motor is and I think that is why he is thinking I cant do better) I don't agree with that just yet. I believe that since I believe I am hitting the REV limiter that I got some HP left. I have looked at a few Yamaha performance bulletins and based on those I can't see how in the great blue world I can't get at least 45-47 with a 19"pitch prop. I will include a link to three different Yamaha performance bulletins below.
Any help or thoughts would be appreciated even if you think I am crazy and have the same frame of mind as the guy that told me I can't get but maybe 1 or 2 more mph
this one has weight similar to mine but has a narrower beam and maybe less tested weight
http://yamahaoutboards.com/sites/def...sa6466.tmp.pdf
this second one might be closer but it still has a higher dry weight of 500#... and still running a 19p
http://yamahaoutboards.com/sites/def...-06-20_FLT.pdf
and a bass boat just because.
http://yamahaoutboards.com/sites/def...sa6e51.tmp.pdf
Anyways, Thanks again for taking the time to check out my post and help.
04-10-2016, 10:21 PM #2Member
- Sep 2013
- Knoxville, TN
- 68
- 16
- 24
Most of us try several props to find what we like best. Look for a used one and try it, you can always resell it.
capt_j_low thanked for this postcapt_j_low liked this post
04-19-2016, 01:44 PM #3
Did you test the boat with all the normal weight and gear as well as a full tank of fuel?
Do you fish alone or...did you take a guy with to test for normal load?
If your on the limiter loaded and under normal conditions try a 17" see what happens....not rocket science.
400 rpm per pitch. 15 - 17 -19 ....you would have to be really hard on the limiter to pull another 800 rpm.
04-28-2016, 11:05 AM #4
Any results yet?
Prop set up question
By gambler bob in forum Props, Setup, and RiggingReplies: 1Last Post: 06-11-2010, 09:14 PM -
prop question
By Michael J Giesler in forum General Boating DiscussionReplies: 3Last Post: 06-23-2009, 10:58 AM -
prop question
By CLIMATEMASTER in forum Props, Setup, and RiggingReplies: 1Last Post: 08-22-2006, 11:40 AM -
prop question
By mer in forum Technical DiscussionReplies: 2Last Post: 12-20-2005, 09:20 PM -
Another Prop question?
By wideopen23 in forum Technical DiscussionReplies: 5Last Post: 04-28-2004, 07:37 PM
