Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 46 to 60 of 100
  1. #46
    Jan 2010
    Venice, FL
    Welp we got the motor on. Reckon the lipstick's gonna have to wait. Eh, least the cowl's painted ...
  2. #47
    Sep 2016
    McHenry,Illinois
    Johnson motor cover makes it look a lot taller. Nice looking rig!!! How does the cav plate work for ya?
    Hustler 15' Wildcat / Merc 80
    Hustler 13' Wildcat / Merc 80
    Hustler 13' Picklefork(Experimental) / Merc 80
    Hustler 16' Victor / Evinrude 85
    Hustler 15' Tunnel / Evinrude X115
    Hustler 17' Lark / Suzuki 140
    Hustler 16' Victor / Johnson 135 (current and restored)
  3. Thanks 71V153 thanked for this post
  4. #48
    Jan 2010
    Venice, FL
    Yeah but I think I'm gonna paint up the old school cowl I got. It's in purty good shape.
    Thanks. Can't take all the credit. Had a lotta help.
    Luv the Bob's True Tracker. Really helps with holeshot. Gotta carbon fiber drag plate I might try later on. After I install the nosecone and get the motor up where it needs to be.
  5. #49
    Jan 2010
    Venice, FL
    Almost got the seat done:
  6. #50
    Sep 2016
    McHenry,Illinois
    I personally like the look of the Evinrude cowl over the Johnson....I'm doing the same thing with my 1975 Johnson 135...painting it the 1988 light blue and using an Evinrude cowl....think it will match the blue old school flake on my restored Hustler. I got to come down on my motor a little...am up to being 1 3/4 down from the bottom and it looses water pressure and speed as I trim out and appears to start blowing out. Just too high for the old OMC gearcase I think. Was thinking about a cav plate to help with the holeshot but am also considering turning my set of 4" setback plates into a hydraulic jack plate...have an old Suzuki trim and tilt system that might work. Don't want to make this boat into a "raceboat" per se...just want to be in the 55-58 range when I want it.
    Quote Originally Posted by 71V153 View Post
  7. #51
    Jan 2010
    Venice, FL
    Next time I'm rich gonna go with a Strangler motif. Or Stinger. One or the other ...
  8. Likes DanUmbarger liked this post
  9. #52
    Jan 2010
    Venice, FL
    Well we finally got a coat of paint on the floor. Scuff and 2nd coat tomorrow. Then start rigging. WooHoo!
  10. #53
    Jan 2010
    Venice, FL
    That effing bug paid with his life. Naturally the cser had to drag himself through the paint bout 3' aft of where he landed ...
  11. #54
    Jan 2010
    Venice, FL
    Dug out that carbon fiber drag plate. Figger I'll get it cleaned up a lil.
    Reckon once I get the motor up high enough I'll give her a shot. Cuz even with the True Tracker this thing throws water everywhere comin outa the hole?
  12. #55
    Jan 2010
    Venice, FL
    2nd coat. Got about 1/3 qt left over for touch up. No bugs. Yet ...
ID:	392045   Click image for larger version.
  13. #56
    Jan 2010
    Venice, FL
    Got the shifter in, and trim ring on for wire bundle. Daylight savings time sucks!
ID:	392127   Click image for larger version.
  14. #57
    Jan 2010
    Venice, FL
    Seat's in:
  15. #58
    Jan 2010
    Venice, FL
    Monkeyed around with the trailer a lil this afternoon. New tongue jack. Had to make my own bolts out of threaded rod, but worked out okay.
    Turned the winch around so the handle's on the right side. Took it apart and lubed it up too.
    Gonna try'n get the steering in tomorrow.
  16. #59
    Mar 2016
    cincinnati, ohio
    We did the transom and knees in one big pour on mine. Just under 5 gals of goo.
    I'm sorry, what do you mean by five gallons of goo??? How did you do the knees and stuff, what is goo???
  17. #60
    Jan 2010
    Venice, FL
    Quote Originally Posted by 1954bmw View Post
    Pourable 'ceramic' transom compound, a la Seacast. We used an Arjay equivalent. AdTech makes one too, and there are probly others.
  1. Opa class 7 continuing to grow
    By 1WATERBOY1 in forum General Boating Discussion
    Last Post: 09-14-2013, 11:18 AM
  2. Help my 225 3l efi grow some bawls!!!
    By FASTCC in forum Technical Discussion
    Last Post: 06-02-2011, 11:43 AM
Spinelli Props
