Page 6 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 76 to 90 of 100
  1. #76
    Yup, she's been eyeballing your work waiting for a ride.
  2. #77
    Jan 2010
    Venice, FL
    Ha! Too bad I only got one seat? And I ain't so sure she'd fit into it ...
  3. #78
    Ha, she'll sit on your lap
  4. #79
    Jan 2010
    Venice, FL
    Fat chance'a that ...
  5. #80
    Give us the fat details on the 140
  6. #81
    Jan 2010
    Venice, FL
    Okay for chit's n giggles we disected the trim switch. Now if'n I could only find my soldering iron ...
    Tank's almost done. And at this time I would like to officially proclaim my love for Plasti-Dip ...
    Discovered they have cans of 'glossifier' and 'metallic-erizer' at the china mart behind the shop. Be interesting to monkey around with?
  7. #82
    Quote Originally Posted by 71V153 View Post
    Motor's purty strong. Scalloped block & pistons, squared off ports, lil knocked off the heads, '77 drilled mid, etc. We're thinkin 80 or so isn't too far fetched?
    Pics
  8. #83
    Jan 2010
    Venice, FL
    Okay ... but it's kinda a frankinrude.
    '77 140 .030, scalloped block and teflon pistons, rod slots cut, rods and pistons balanced. '78 hi comp heads minus a lil. Later model (taller) intake w/recirc lines, stuffers, and Carson reeds. Large bore type III carbs with primers. Upgraded to CD4 unlimited single powerpack, flywheel and ignition. Relieved '77 megaphone mid.
    That's about all's I kin come up with for now ...
    Attached Thumbnails Attached Thumbnails '77Tuner.jpg   Scallop.jpg   RodSlots.jpg
  9. Thanks FMP thanked for this post
  10. #84
    Jan 2010
    Venice, FL
    Might square off a set of reed cages next time I grow a wild hair up my butt ...
  11. Thanks FMP thanked for this post
  12. #85
    Can you run without the reed stops? Spread wide?
  13. #86
    Jan 2010
    Venice, FL
    Heard tale of cutting the stops down a lil. Never running without?
  14. #87
    Different applications but the five finger Chrysler then Merc . Two stage reeds without gained 75 rpm. Never broke one, hundreds of hrs. First spread the stops as wide as the case would fit, then removed them keeping the strip along the screw holes. If I remember the instructions said remove for the V4.
  15. #88
    Jan 2010
    Venice, FL
    Ya this thing had never been run. Two stage Boyesons in it when I got it. But I'm kinda partial to Carson reeds.
    I'm told some of the later/cleaner Ficht cages will fit in an xflow intake. But have yet to experiment.
  16. #89
    Sure ,a little more choice for stiffness with CC. I'd pull the stops and see what's up after you mod the cages.
  17. Likes 71V153 liked this post
  18. #90
    Jan 2010
    Venice, FL
    Two coats on top of the tank. Almost done. WooHoo!
  1. Opa class 7 continuing to grow
    By 1WATERBOY1 in forum General Boating Discussion
    Last Post: 09-14-2013, 11:18 AM
  2. Help my 225 3l efi grow some bawls!!!
    By FASTCC in forum Technical Discussion
    Last Post: 06-02-2011, 11:43 AM
