Page 2 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 16 to 30 of 100
    Quote Originally Posted by CUDA View Post
    Is this the same boat>
    Chris Ray would pull two boats to the ODBA races, that's Trex and Ray bottom picture and Marty with Ray above.
    Marty drove the tunnel in your picture.
    Ray switched to a 1/4 Master and moved the drivers seat back a few feet ...
    I totally remember that dual-trailer setup! I always wondered what it would be like to tow that rig.
    Very cool boat project there - keep us updated on your progress. That one looks like it will be fantastic.
  2. #17
    Jan 2010
    Venice, FL
    Preciate the encouragement Greg. If you like the project figger I must be doin somethin right ...
    Fairly sure this is the same boat Cuda pictured.
    Oughta be alotta fun when I get it done. Stay tuned ...
  3. #18
    Jan 2010
    Venice, FL
    Knees out. Lil more finish grindin/sanding to do but gettin purty close to reassembly. WooHoo!
  4. #19
    May 2009
    Myrtle Beach
    I might have missed it... But did the transom check out O.K.?
  5. #20
    Jan 2010
    Venice, FL
    Quote Originally Posted by FoFittyFoSS View Post
    We did some tapping and poking around in there and it appears to be. No visible damage ...
    It's not very thick. Barely 1 1/2". Thinkin I might beef it up inboard with a piece of material behind the new stringers and knees. Figure that should prevent any problems?
    Got her almost all cleaned up:
  6. #21
    Jan 2010
    Venice, FL
    Got the knees cut out, ready to laminate. Need to pick up some resin tomorrow.
    Many thanks to Dago for the 3/8" Nidacore. Three 2 x 4 sheets and one with a tiny rectangle off of one corner. More than enough for the floor and to beef up the transom. Much appreciated Mike!!
    Looks like I have plenty of biax and mat. WooHoo!
  7. #22
    Jan 2010
    Venice, FL
    Pic of the bottom:
  8. #23
    any updates on this restoration ?
  9. #24
    Jan 2010
    Venice, FL
    Quote Originally Posted by phillnjack View Post
    Sadly not. Was goin good til I wound up in the hospital again with this friggin diverticulitis.
    The C500 is in my buddy's shop now. This boat is next.
    Did scrounge up a running '79 flat back 115 w/good compression. Need to go through it and add my spare bubble butt exhaust, etc. That'll go on the Baja after we swap my 140 over to this one.
  10. #25
    Oh sorry to hear you been in the hospital. hope everything goes ok for you.
    will the bubble back exhaust make much difference to the motor ? I mean is this a very noticeable gain ?
    I know the difference to look at, but never realy got into knowing exactly what is inside them.
    My friend has a1977 Johnson 140 model ML77s that has the bubble back and the special tuner, I had the Johnson 85hp flat back.
    also know its a pain to do the thermostats with the bubble in the way !!
  11. #26
    Jan 2010
    Venice, FL
    Okay boy's girls. Project back in full swing for the past few weeks. Wound up doing the transom, and knees in one big gob of pourable goo. New stringers and floor in. Bout ready for primer:
    Attached Thumbnails Attached Thumbnails DSC00248.jpg   DSC00243.JPG   DSC00246.jpg
  12. #27
    Jan 2010
    Venice, FL
    Quote Originally Posted by 6Killer View Post
    I used to have to add 40lbs to that boat to make 1050 for V4 comp.
    Slowly it started to get heavier and required less weight.
    It was really beat up when I bought it. I hope you do something cool with it.
    Dave, Mike was never upset.
    One time we kicked his cane out from under him in front of a girls Volly Ball team. This really tall Amazon, bent down and picked him up like he was a baby.
    He was in luv!
    Good times..............
    Don't spose anybody'd know where the title to this thing is? ...
  13. #28
    Jan 2010
    Venice, FL
    Coat of 2K primer:
  14. #29
    shreveport,la
    I had an 83' 16ft speedcraft, canary yellow.. put new stringers and full height knee braces in but the orig balsa core was unharmed at 15 yrs old.. It weighed around 370lbs (est 340-350 new) with a very solid running surface after the redo..Originally the boat belonged to Tommy & bobby sanders (Da Bull) had a 2.6 liter 235hp omc on alcohol, I put a warmed over 140 evinrude on it and later a 260 cut steel sleeve 2.5 merc.. boat was very quick and a breeze to drive..
    Just don't over trim it, you won't go any faster and if ever it gets a lung full of air you're gonna have an interesting day.. I often miss that boat, to drive it felt like wearing it.. Very natural feel to those hills..
    Kevin Kiser
  15. Likes 71V153 liked this post
  16. #30
    Sep 2010
    toronto, canada
    Quote Originally Posted by Ted Stryker View Post
    Agreed on every aspect of that - super easy boat to drive once its set up properly - almost feels like its on rails. I had mine set up with a 12" 245 and it felt like it handled the same at 60 and at 100. I had mine weighed once it was done and with beefed up knees and a double stringer running down the center it came in at 374lbs with the seat and gas tank.
  17. Likes 71V153 liked this post
  1. Opa class 7 continuing to grow
    By 1WATERBOY1 in forum General Boating Discussion
    Last Post: 09-14-2013, 11:18 AM
  2. Help my 225 3l efi grow some bawls!!!
    By FASTCC in forum Technical Discussion
    Last Post: 06-02-2011, 11:43 AM
