Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 31 to 45 of 75
  1. #31
    Jul 2002
    Las Vegas, NV
    Are you planning to support the top of the cowl with the bracket/pin/spring pin that is used on the hi-perf cowls? If not, remember that your pan is supporting the full weight of the cowl and it's oscillations due to boat movement. Stiffer is better. The stock pan is stainless sandwiched between the powerhead and adapter.
    Keith-
  2. Thanks greatwhite85 thanked for this post
    Likes rock liked this post
  3. #32
    Quote Originally Posted by rock View Post
    When I first started following this thread I kinda thought you were nuts. I would have just bought one. Your process has been pretty well thought out and your final product is looking like the target. Still think you might be a little nuts but I admire your perseverance. Looking forward to seeing the final product painted with decals. Good job.
    Rock
    He IS nuts, but that thing is coming out really nice.
  4. Thanks greatwhite85 thanked for this post
    Likes greatwhite85 liked this post
  5. #33
    Quote Originally Posted by greatwhite85 View Post
    OK time to rant. I am definitely a "newb" at posting on a thread. But every time I login with my username to scream and fly and then type out all the updates and add pictures and then post. It tells me that I need to refresh the page and login again. Usually I can scroll back to find everything I typed out and then post it. But sometimes I lose everything I wrote out and have to start all over again. This has happened a few times since I started this. Could this be something I can fix in my settings or do I just have to deal with it? Oh well I will work around it and try again tomorrow
    It's not you. The site is undergoing some upgrades so it's a little goofy, and some functions are temporarily disabled like "auto save"
  6. Thanks greatwhite85 thanked for this post
  7. #34
    Jul 2011
    San Diego
    Quote Originally Posted by STV_Keith View Post
    I wasn't planning on it, but now that you mention it I will think about it. I certainly wouldn't want this thing to start "tweaking"on me. Perhaps maybe some "pads" underneath for it to rest on. I'm not opposed to the spring and pin method. I always apply a little over-kill cause it helps me sleep at night.
  8. #35
    The other thing I've wondering is... how much does this thing weigh? I can weigh mine if I can get it down without emptying the building first.
  9. #36
    Jul 2011
    San Diego
    I weighed it before I started working on it and it was at 16 lbs. but that's not counting the pan which I won't know until it's finished. I would have to guess around 20pounds when it's finished.
  10. #37
    Jul 2011
    San Diego
    Rock
    lol. I'm definitely nuts no doubt about it. The worst part about it is that I am strapping this on a whopping 150. Yeah, thats right a 2.0 liter stock ass 150 that is bolted to a 1972 16 foot challenger ski boat. So I had to break one of my own rules to have a 100 mile-per-hour looking boat that currently can't break 60 mph. I will be exposed the first time I get smoked by a Jetski. That's OK I've made my peace with that. I feel the work I will put into achieving that look will mean i've earned it and by next season I plan on buying a 200 powerhead to justify the look. Until then ill be "that guy"
  11. #38
    Jul 2002
    Las Vegas, NV
    To my point about the pan supporting the cowl...I haven't weighed mine, but I'd bet the lift off cowl is only about 6-7#.
    Keith-
  12. #39
    Jul 2011
    San Diego
    Wow, That is certainly as light weight as it gets. I will definitely add more support. I knew it wasn't going to be as light weight as the real thing. But it will still be lighter than the cowl that I am replacing it with. The clamshell Cowl weighs 25 pounds when you include the aluminum bracket that bolts to the back for the hinges.
    Just one question I read somewhere that these Bridgeport Cowls are made of plastic. Is that true ?
  13. #40
    Yes..
  14. Thanks greatwhite85 thanked for this post
  15. #41
    Jul 2011
    San Diego
    Sooner or later i will have to make a front cover, So I am again in need of measurements. I was going to guesstimate based on the dimensions of the decals I have for It, but if someone could send me the measurements i'd really appreciate it. Here's a sketch of which ones I need which are pretty much the whole thing.Click image for larger version.
ID:	343257 ... And of course the picture came out sideways again.
  16. #42
    Mine weighs 15# including the pan/tray... 8.5# for the upper alone.
    Approximate dimensions:
  17. Thanks greatwhite85 thanked for this post
  18. #43
    Also, those five openings at the top are more like "louvers" punched in, opening to the front, than holes.
ID:	343264Click image for larger version.
    The thing really looks more to me like it was heat/vacuum formed from two sheets than injection-molded; but I really don't know. The openings in the louvers look they were hacked out with die grinder or small axe. LOL
  19. #44
    Jul 2011
    San Diego
    Thank you David. Perfect, you even included measurements I didn't even think about like thickness and distance off the Cowl. I'm thinking I will make it out of plywood and "bar-top" Epoxy coat it before primer and paint. Perhaps I could hollow the inside with a router To lighten it up a bit.
  20. #45
    Jul 2011
    San Diego
    Yes this part will be one of the most noticeable of the subtle differences. I will add a piece that will be glued to the inside that will act as louvers similar to what's on the real thing. After adding the two vent holes I noticed they are slightly larger on this black Max. On the Bridgeport cowl The five louvers stretch across to about halfway between the very top line and on mine it goes about 1/2" or so beyond that. This is a difference that I can live with, it doesn't look that bad to me and Little extra airflow shouldn't hurt.
  1. Allisonxr2001 rear cowl.. For two seat conversion
    By Phil Conant in forum Misc. Parts and Accessories
    Last Post: 12-14-2015, 07:47 AM
  2. 3 litre alian hood conversion
    By Image 21 in forum Appearance Mods
    Last Post: 04-09-2013, 09:45 AM
  3. Alien Cowl Conversion
    By halveb in forum Technical Discussion
    Last Post: 03-05-2010, 02:09 PM
  4. latest creation 3 litre alien conversion complete
    By Image 21 in forum General Boating Discussion
    Last Post: 01-24-2009, 01:54 PM
