Results 1 to 6 of 6
02-09-2016, 10:57 PM #1
Flywheel / stator charging question.
I need a new flywheel and it got me thinking about something.
Yamaha doesnt have a low amp flywheel like you Merc guys do. Its my understanding that the flywheel/stator is basically a generator. The generator uses power from the engine to create amperage. A lower amp system uses less power robbed from the engine.
My boat has almost no electronics. I have the engine, trim, and fuel pump.
If my flywheel had, for example, 12 magnets and I could remove 3 of them evenly to maintain balance, could I create a lower amp system?13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
02-09-2016, 11:04 PM #2
I know brendan power changed magnets to increase output and actually ended up with too much output at the RPM they aimed for. Thats what I got out of it when I was there and he had a flywheel he wanted to try on a 40 amp system. He had a tool to measure the strength of the magnets also. Might be worth giving him a call
E-tecs also use a much different magnet and every other magnet has opposite polarity of the one next to it. THe little ones seem stronger then the old carb motors 10x their size.
Subscribed
02-09-2016, 11:10 PM #3
Yea like I said I have no idea on how the magnets vs pickups effect things. Probably not as simple as I would like.....
21' Paramount
Mercury 300 Promax
02-10-2016, 02:37 AM #4
Wouldn't it be a generator and a magneto? Seems you would need to know which magnets are used for ignition vs battery charging.
There is only one way to avoid criticism: do nothing, say nothing, and be nothing. –Aristotle
Quinten
86' Hydrostream Vking YT, 2.4 Bridgeport EFI
(Rigging and interior in the works)
88' Hydrostream Voyager, 2.4 200 Merc
Boat of The Month Feb. 2009
resto here, http://forums.screamandfly.com/forum...d.php?t=144414
Dedicated to you Dad, I miss you! 1935-2008
02-10-2016, 09:11 AM #5
02-10-2016, 09:27 AM #6
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
Swapping to 16 amp stator and jsre flywheel on 98 225pmax wiring question
By phase3looper in forum Technical DiscussionReplies: 11Last Post: 08-15-2013, 09:10 PM -
Fried charging ststem and stator on 200 merc
By XstreamVking in forum Technical DiscussionReplies: 2Last Post: 11-30-2011, 04:34 PM -
Is a lite flywheel useable with a standard charging system?
By WATERWINGS in forum Technical DiscussionReplies: 26Last Post: 04-14-2003, 07:17 PM
