Results 1 to 15 of 28
    Dec 2011
    florida
    virage restoration
    After a 1800 mile move and 5 months I'm finally ready to start working on the virage. It had some bow damage when I bought it. With the 12 month boating season in Florida I never wanted to disable it, but now that in in Michigan its time. Here are a few pics of the damage and splitting the deck
    Attached Thumbnails Attached Thumbnails KIMG0144.jpg   KIMG0150.jpg   KIMG0155.jpg   KIMG0156.jpg   KIMG0158.jpg
  2. Likes 59powercat1400, Laseraddict liked this post
    Feb 2003
    Mesa, AZ
    Cool. Keep the pics coming.
    Mar 2010
    Brigham City, Utah
    The damage shouldn't be hard to fix. Just grind in down to solid glass and start building it up with Chop Strand. Mine wasn't as larger an area and I guess the hard part will be rebuilding teh upper lip.
    Pic #5 looks like the front of my 1973 Corvette.
    Good luck with the resto.
    Karsten
    Jun 2004
    Lakeridge NY
    I'm in the same boat, literally
    (Apricot)
    Hydrostream Ventura II/Merc
    (sold)
    (Bruiser Scheme)
    Hydrostream Viking/Merc
    (sold)
    (tri color letdown scheme)
    Hydrostream Valero/Merc
  6. Likes Laseraddict liked this post
    Jun 2004
    Lakeridge NY
ID:	336570Click image for larger version.
    (Apricot)
    (sold)
    (Bruiser Scheme)
    (sold)
    Jun 2004
    Lakeridge NY
    (Apricot)
    (sold)
    (Bruiser Scheme)
    (sold)
    Dec 2011
    florida
ID:	336611Click image for larger version.
ID:	336609Click image for larger version.
    Got the old repair cut out. The hole was much larger than expected. I made a mold out of flexible plywood screwed to the bottom and used tinfoil so the glass didn't stick to the mold. The repair is a single piece of wolven glass molded to the conture of the hull The repair turned out excellent. I will still have to fill and finish sand the bottom surface. While waiting for the glass to dry I checked the foam in the starboard sponson. It was completely waterlogged.
    Mar 2010
    Brigham City, Utah
    I didn't see the hull damage in the above pictures...that is a pretty big hole to repair.
    Best of luck with that.
    Karsten
    Dec 2004
    WINTER HAVEN,FL
    We had a virage here in Central Fl. just like yours took a ride up though the trees one night, boat was tough as the driver !
    IT AIN'T FAST , IF ITS NOT ALLISOON MAN POWER!!!
  12. Likes Laseraddict liked this post
    Dec 2011
    florida
    Here are the latest pics of my progress on the virage. The bottom hull is blocke out just needs a skim coat of filler before primer. The wood along the top edge of the hull were replaced to get the fit as close to factory as possible. I made a mold fitted to inside of the deck and reattached the two halves. I laid 3 layers of chop mat. After it dried popped it apart trimmed the lip and removed the mold. It went back together perfectly. Just a little block sanding and I should be ready for primer.
    Attached Thumbnails Attached Thumbnails KIMG0181.jpg   KIMG0187.jpg   KIMG0177.jpg   KIMG0185.jpg   KIMG0183.jpg
  14. #11
    Dec 2011
    florida
    Mar 2010
    Brigham City, Utah
    Awesome progress and it is turning out great. Keep it up and post the work as you go.
    Karsten
  16. #13
    Jun 2009
    Bristol, Connecticut
    I am restoring a Virage and will need to do slight repairs to the front like you did you fix some stress cracks. But looks like the previous owner of your Virage hit the bow on something and then fiberglassed the two halves together.
    There was a repair on my Virage on the right corner near the transom. They fiberglassed the two halves together so I had to cut away part of the top deck where the rub rail goes. I will be doing a similar repair so thanks for giving some tips.
  17. #14
    Jun 2009
    Quote Originally Posted by rossi View Post
    Hi how much did you grind away on the sides of the sponson where the edge of the two pieces of floor meet? I ground too much in some areas (around where the ski locker would be) and the fiberglass is very thin. I will need to add fiberglass on each of those humps to properly seat the floor so it's level and has enough thickness to sit on.
  18. #15
    Rhode Island
    We haven't heard back from this fella in a while now... I hope his project didn't lose steam!
  1. Restoration Help
    By vnemous in forum General Boating Discussion
    Last Post: 12-30-2007, 03:10 PM
  2. 850 XS Restoration
    By Tom Smyth in forum Outboard and Racing History
    Last Post: 12-03-2007, 06:50 PM
