Results 1 to 15 of 28
    Mar 2010
    houston, tx
    Promax vs 260 vs prostock
    I've seen various dyno charts for stock promax. They usually fall between 240-249 hp on the limiter.
    Does anyone have a dyno chart for a pm with raised limiter compairing 260@ 8k vs a pm @ 8k etc
    what about a stock 260 dyno and one with 26cc heads.
    Pm with drag electronics with 26cc heads
    prostock legal powerhead with 32 or 26cc??
    thanks!!!
  2. Likes ironhead stv liked this post
    Aug 2012
    beaumont, tx
    Subscribed.
    ^^x2^^
    longisland ny lindenhurst
    ^^x3^^
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft sleekcraft modvp
    18ft action hst drag
    18ft accelerator drag
    21ft redline
    18ft vking yt
    20ft Allison grandsport
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
    X4
    Mar 2011
    Virginia
    This sheet is from a stock Promax with SVS and Brucato ECU with dyno tune.
    Go Time
    26 Regulator twin 250 EFI
  8. Likes tux974, Laseraddict liked this post
    Quote Originally Posted by Go Time View Post
    Now get Lee to play with a 260 and post up needed details.....
    Stock 38CC heads correct?
  10. Likes Laseraddict liked this post
    Mar 2011
    Virginia
    Yep, stock heads and 23 degrees WOT
    Go Time
    Aug 2012
    beaumont, tx
    I see the torque falling off...but when does the HP fall off higher than 7500?
    I would guess the prostock motor's torque would peak lower. But when u turning a 22" who cares.
    I'd love to get my hands on a prostock tune for a brucato....gonna have to sneak one off some bodies boat at the race this year. Ninja skills!
    Mar 2011
    Virginia
    I have my limiter set at 7600 rpm
    Go Time
  14. #11
    I have a Merc Racing brochure somewhere that had HP and torque graphs. All the 2.5's showed peak torque arounf 5-5300rpm, 280, Pro Max, and Drag.
  15. Likes tux974 liked this post
  16. #12
    Prince George B.C. Canada
    So what is the difference in a promax prostock compared to stock? Fuel delivery? Numbers look great!! Mine revs with Tonys box to 7500+ with 33cc heads. But at around 7300 seems to be the sweet spot as confirmed buy the chart it would seem.
    Aug 2012
    beaumont, tx
    I know the prostock 200 motors are running high psi curves with custom tunes....some run 56lbs some turn down to 50 lbs
    I would think pmax would benefit the same doing this
    I know my laser front 260 woke up when I went to a 56lb curve
  18. Thanks whipper thanked for this post
  19. #14
    Mar 2010
    houston, tx
    Quote Originally Posted by texasvector View Post
    I know the prostock 200 motors are running high psi curves with custom tunes....some run 56lbs some turn down to 50 lbs I would think pmax would benefit the same doing this I know my laser front 260 woke up when I went to a 56lb curve
    ive seen a "prostocked" pm run once, it was pretty mean for a unported pm. defintitley made a big change. interesting that you put a laser injection on a 260, most i see are horns on pm's LOL. But for 660, i'm wondering if a promax with drag electronics would be faster than a 260. No doubt in 1320 the 260 would get it, btu in 660 i'm not sure...
  20. #15
    Aug 2012
    beaumont, tx
    Well..it was a 245...took carbs off and put efi
  1. odba prostock
    By shawnjetton in forum Racer's Hangout
    Last Post: 01-10-2008, 08:03 AM
  2. ProStock, ODBA
    By LARRY D in forum General Boating Discussion
    Last Post: 03-27-2007, 07:27 PM
