Results 1 to 4 of 4
    Mar 2010
    australia
    Mercury 200 Alarm
    A friend of mine has a 2004 200L EFI Merc. Yesterday whilst on the river the alarm beeper was intermittently sounding and the engine would lose power. The engine had plenty of water pressure and was not over heating and the oil bottle had plenty of oil in it. What else would make the alarm beep.
    My thoughts would be maybe there was a bit of water in the fuel... Anyone else got any thoughts?????
    Mar 2010
    australia
    Ttt...
    Four beeps every 2 mins means oil level low, or water in fuel filter. Drain the filter to check it. May be the oil level sensor giving a false warning. The float gets oil soaked and sinks causing the alarm. Fairly common on older motors. The test is to jump the blue and black wires at the tank sensor. Disconnect from tank, hook them together on the motor side with a jump wire and see if the alarm goes away.
    Mar 2010
    australia
    Could a sick battery also cause the 4 beeps every 2 mins?
  1. 1991 2.5L Mercury 200XRi Oil Alarm
    By orbeamlb in forum Technical Discussion
    Last Post: 09-03-2012, 08:38 AM
  2. Mercury Tech: 1993 Mercury 50 Alarm
    By hevysrf in forum Technical Discussion
    Last Post: 06-09-2011, 09:25 AM
  3. Mercury alarm
    By hydrostreamin! in forum Technical Discussion
    Last Post: 05-19-2010, 12:06 PM
  4. Mercury 250 Ofshore alarm problems
    By haolecrab in forum Technical Discussion
    Last Post: 12-16-2006, 05:48 PM
  5. Mercury 225x Alarm ??
    By REBEL in forum Technical Discussion
    Last Post: 09-07-2003, 10:59 PM
