Results 1 to 10 of 10
    Jul 2010
    Welling
    2000 Promax 225 for sale
    I have 2000 Promax 225 for sale that is literally a new engine. In April of 2013 I had a bad experience with a dirty injector and damaged the piston in the 4 hole on a fresh rebuild with less than 50 hours...I wasn't happy to say the least. After searches and calls mercury came through with a Brand new power head...not a reman/rebuilt...I wanted a factory new, never seen gas/oil power head...it was costly but well worth it.
    I had everything that could be suspect replaced new; oil pump, stator, coils, wires, voltage regulators, etc. I also had the injectors rebuilt and flow tested as well as the ECU mapped and checked over.
    The new engine was re-installed on the boat in August of 2013, since then I have put less than 40 hours on the engine...only took the boat out twice last year. I have it installed on a Ranger boat so it's not been raced or abused.
    I has the torquemaster lower with the fat shaft; I had the lower painted...but as normal it doesn't stick well and is starting to revert back to its original finish. Due to the paint on the lower peeling, Cosmetically I'll give the motor a 8.75 on a scale of 1 to 10...but I'm picky. Performance and under the cowl fit and finish is 100%.
    This is a rare opportunity and you wont be disappointed.
    I also have the 1st power head that needs the 4 hole repaired I can send pics as well if need. This motor cold easily be parted out if repair was not desired...heads, block, crank, etc as these are undamaged. Just a piston with withered edges I'd like to sell both together.
    8500.00 will get you a new promax and the old power head.
ID:	335046   Click image for larger version.
ID:	335045   Click image for larger version.
ID:	335047   Click image for larger version.
ID:	335048   Click image for larger version.
    BOISE
    Sounds like a sound engine, I would like to visit with you more about it when you have time give me a call 208-860-3018 thanks,, I am Dave
    Jan 2016
    Deland,fl
    Would you be willing to sell the original block ? Just the 4 hole is damaged ?
    Quote Originally Posted by PMAXED View Post
    . Would you be willing to sell the old block? Has it ever been sleeved or bored ?
    Jul 2010
    Welling
    Sorry for the delayed response...been out for a while. I would sell the old long block separately; it was bored on the previous build. All other cylinders held 130lbs compression. I have attached a couple of pics of the old block as well.
    Thanks for asking
ID:	338128Click image for larger version.
    Feb 2016
    Toronto, Ontario, Canada
    Please post a photo of the entire motor with the cowling on. Thanks
    Central NJ & Ft. Pierce, FL
    Where is Welling?
    Jul 2010
    Welling
    I have attached a couple pics of the motor..Click image for larger version.
Name:	iphone end 031316 138.jpg
ID:	339257Click image for larger version.
Name:	iphone end 031316 140.jpg
ID:	339258Click image for larger version.
Name:	iphone end 031316 139.jpg
    I also used Carlson reeds instead of the factory reeds...
    Jul 2010
    Welling
    Welling is Northeastern Oklahoma, near the town of Tahlequah, OK.
    Jul 2010
    Welling
    Complete engine and old power head are sold.
    Best
    Sep 2014
    piedmont S.C./hickory hill TN.
    O yea!
