Results 1 to 8 of 8
Thread: Push-button start?
01-18-2016, 03:30 PM #1
Push-button start?
Has anyone here made a switch style, push button start out of a Mercury wiring harness? I know they used to have one but it's no longer available. I believe it used 3 switches.
Mirage Jaguar RiverRacer
Polaris PRO785
Bennington 255LCC
Scream & Fly Flying Machine of the Month: September 2005
http://www.screamandfly.com/showthre...ild&highlight=
01-18-2016, 08:20 PM #2
Friend did it on a 260 with rocker switches, start switch was spring loaded like a horn switch.
01-18-2016, 08:37 PM #3Mirage Jaguar RiverRacer
Polaris PRO785
Bennington 255LCC
01-18-2016, 09:03 PM #4
Never see a Race harness but would assume they don't have all the trim and gauge wires as a regular harness.??? All the wires that are needed for ign should be the same color.
01-18-2016, 09:04 PM #58000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
Bob rigged one up on the dr 20
01-18-2016, 11:52 PM #6
I believe all F1 type race boats are setup with push,plus24V start system to help get best reaction time out of hole and be first one to turn bouy
"Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
2007 Sportsmen Driver of the Year
01-19-2016, 09:33 AM #7
They are just momentary toggle switches for the starter on the race setup. 1 for ign., 1 for prime, 1 for fuel pump, and 1 for start and the old ones like on the T2's had a kill switch(the kind that attached to your jacket when you got tossed out at 100+, yee haw)
01-19-2016, 09:15 PM #8
Super simple if you just want to have a push button starter and leave your key switch to turn on/off the ignition and acc... Take the yellow/red stripe wire off the key switch hook it to one terminal on a momentary push button switch hook the other terminal to the purple wire on the back of the key switch and ur done. the key will do all the other functions except start and the button will do that, they have some really cool ones out with led rings . dave
WTB a old style mercury 2.4 Preload, top push button drive shaft for 20" lower unit
By bkwalk in forum Parts WantedReplies: 5Last Post: 08-06-2015, 07:12 PM -
mercruiser230 no start with ignition in start position
By chriscraft291 in forum Technical DiscussionReplies: 3Last Post: 04-08-2013, 02:27 PM -
Yamaha Tech: Question about adding recoil start on an electric start 9.9 Yamaha - can it be done?
By Steve2ManyBoats in forum Technical DiscussionReplies: 3Last Post: 09-11-2012, 06:12 AM -
push button start
By thunderstruck racing in forum Technical DiscussionReplies: 1Last Post: 08-31-2010, 09:13 AM -
How do I rig a Start Button?
By Pete in forum Technical DiscussionReplies: 3Last Post: 12-29-2003, 08:49 PM
