Results 16 to 30 of 32
Thread: 1979 Checkmate Exciter Part 1234
02-01-2016, 10:43 PM #16Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Dave's not here man looks good.
Ronny's Marine thanked for this post
02-01-2016, 11:03 PM #17
NICE PAIR liked this post
02-08-2016, 03:30 PM #18Member
- May 2014
- High Point, NC
- 50
I'm curious to know how you did the flake/gel. Did you use one of those flakebuster guns? Where would someone have to go to acquire that much flake? also, what kind of equipment is required to spray gel? ive read you have to use a cup-gun, did you just thin the gel and use a larger diameter nozzle so you could use the gravity feed gun? thanks.
02-08-2016, 06:39 PM #19
That flake is awesome.
I bought a smaller Cup gun and a standard siphon style both with larger tips for my up coming gel job. I have seen Dump Guns as well as HVLP guns used for Gel. I am hoping the HVLP guns wont waste as much Gel and Flake due to the lower Operating pressure than the 70 PSI of a Dump Gun.
For Metal Flake I search Ebay for 2 suppliers and mixed a couple colors to come close to the Orange on my CVX-20 I am doing. At this time I have a little over 3 pounds of flake 015-.025
I can only hope my gel comes out half as nice as that Checkmate.
Karsten
02-08-2016, 08:33 PM #20Member
- May 2014
- High Point, NC
- 50
so are you spraying your flake while its suspended in the gel or spraying a thin layer of gel, let it tack, then the flake, and then gel over that? I know this is how they do it in the industry.
02-08-2016, 09:36 PM #21
Humm, Plan is a base coat of RAL2004 Orange colored gel then 4-5 or more coats of Clear Gel mixed with flake until the desired effect is achieved on the upper deck.
Hull for the most part is Fighting Lady Yellow mixed from Neutral Gel, white and yellow pigment.
Finish with a coupe more coats of clear gel mixed with Duratec High Gloss Additive and Wax .
What I have now.
What I hope to end up with.
Now let's hope Ronny get's back in here as I still what to learn as much as possible so I can get this done.
Karsten
02-09-2016, 12:25 PM #22
No wax required with Duratec Hi Gloss.
Do a test run with your gel to make sure it is compatible with the Hi Gloss.
1994 16' Murphy 1991 115 Merc
1985 12' Charger 1989 70 Merc
1981 18'DL Charger 1989 200EFI Merc
Ronny's Marine thanked for this postRonny's Marine, NICE PAIR liked this post
02-09-2016, 07:17 PM #23
Murph,
Thanks, I am getting all my supplies from one place....Fiberglast. They recommended the Duratec High Gloss to cut down on sanding and also advised to add wax to any surface below water to achieve Maximum Hardness.
https://youtu.be/4t45KuOLDA8
Karsten
02-09-2016, 08:23 PM #24
Thanks Murph for giving info you do very nice work
We will add info suppliers and process when the job finishes
If you need to call
Ronny 705 SIX FIVE 3 -Seven 0 Eight four
ronnysmarine.com or ronnys.ca
02-09-2016, 09:04 PM #25
03-02-2016, 10:25 PM #26
<iframe width="560" height="315" src="https://www.youtube.com/embed/J9TLVpkKz-k" frameborder="0" allowfullscreen></iframe>
03-17-2016, 08:37 PM #27
Sneek Peek
<iframe width="560" height="315" src="https://www.youtube.com/embed/QVXCJFVd5t0" frameborder="0" allowfullscreen></iframe>
03-17-2016, 10:12 PM #28Member
- Jun 2010
- over there a minute ago
- 81
- 11
- 90
- 20
That right there is some ''Pretty Work'' !!! You definitely have some mad gelcoat'n skills . That Checkmate never looked better . I'm hoping you will share some of your equipment , material and technique secrets with an old dog that is looking to learn a few new tricks . capt bart
03-21-2016, 08:19 PM #29
<iframe width="560" height="315" src="https://www.youtube.com/embed/gUdc8d6v_iw" frameborder="0" allowfullscreen></iframe>
03-22-2016, 12:19 PM #30Member
- Jun 2010
- 81
- 11
- 90
- 20
looking good , ronny . there is an awful lot of work to getting a result like that and you sure do make it look a lot easier than it actually is . i guess now you need to hang a motor on her and take her for a ride or two . capt bart .
Ronny's Marine thanked for this postRonny's Marine liked this post
1979 Checkmate Exciter 18'6"
By Wildman78 in forum Hulls up to 20'Replies: 6Last Post: 10-26-2015, 04:53 PM -
1979 checkmate exciter with mercury 220 efi. Excellent condition!!
By rbeersy in forum Hulls up to 20'Replies: 2Last Post: 09-06-2014, 02:32 PM
