Results 1 to 4 of 4
01-04-2016, 03:16 PM #1
Prop help needed, single engine 24ft cat
Hello All-
I am in the process of prop testing a 24ft aronow cat with a single 250xs (275hp @ 6000rpm) small shaft fleet master case.
http://www.screamandfly.com/showthre...ect+half+speed
The boat will never be fast but I just want it to run better than it is now.
I currently am running a 22p stock bravo 1 prop. It has way too much tail lift and has a bad porpoise at wide open.
Looking for a new prop in the 22p range, 14.5 diameter, over hub style, small shaft and gives a lot of bow lit. Does anything like this exists?
Thanks
DonLast edited by DonG; 01-11-2016 at 08:25 PM.
01-05-2016, 11:07 AM #2
I'll chime in although I've never had a 24 cat. Most likely tail lift or prop isn't causing your high speed porpoise, it is due to the fleetmaster lower unit is deep in the water combined with you're boat not achieving the speed necessary to drive through the porpoising.
A couple of questions...Do you have a low water pickup? Do you have a jackplate where you can raise and lower the engine? How many rpms can you turn the propeller you're using? If you move weight forward or back when porpoising, can you tell a difference in severity of it? ( have your buddy go from back seat to under the bow)
01-09-2016, 08:16 PM #3Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,645
- 606
- 923
- 1699
- 7152
- 3 Post(s)
Don,
Get a pro et. They stay hooked up as good as anything and won't give you all of the transom that you are getting from that big thru hub.
01-10-2016, 09:06 AM #4
110mph with a single 200 in a 24ft Single engine Catamaran ?
By Pachanga_rick in forum General Boating DiscussionReplies: 11Last Post: 10-27-2015, 07:25 AM -
What's the worlds fastest single out board boat to 100mph 18-24ft
By whipper in forum General Boating DiscussionReplies: 103Last Post: 09-12-2013, 05:36 PM -
Single engine single lever control options?
By Mr. Demeanor in forum Technical DiscussionReplies: 0Last Post: 12-03-2008, 12:32 AM
