Results 1 to 4 of 4
    Jun 2010
    Clearwater,FL
    Question Has anyone honed new rods for 3.3L Evinrude?
    Hello, I'm rebuilding a 2005 Evinrude 250 Etec 3.3L powerhead for use as a fishing boat motor. I'm installing new WSM connecting rods. The new rods look beautiful with nicely polished bearing surfaces. What is the opinion on lightly honing a crosshatch pattern on them? I've heard this will help the needle bearings roll better and reduce the chance of them sliding. Or should I run them as is?
    Thank you
    May 2001
    The Villages, Florida
    Run them.
  3. Thanks wingtime thanked for this post
    Likes ironhead stv, wingtime liked this post
    May 2002
    Victorville ca.
    Bearing skidding only happens at extreme high RPM or when the bearing has no load. Putting a cross hatch on a bearing surface will only increase the rollers resistence which intern will cause more heat. I would leave them alown and run them as they are.
    Jun 2001
    Clyde NEW ZEALAND
    The clearance the rollers have between the rod and crank is what makes them roll not the surface finish.
    Popey
  1. Need cylinders honed
    By 93mustang97sea in forum Other Motorsports
    Last Post: 05-06-2010, 07:20 PM
  2. Evinrude Rods
    By Hooty in forum Technical Discussion
    Last Post: 08-19-2002, 10:48 PM
