Results 1 to 13 of 13
Thread: Throttle body injection help
11-25-2015, 09:16 PM #1
Putting together a motor for my Switzer ss.Its kinda more or less a pro max 225 copy.Couple of things I'm not sure of, Are the throttle body bores all the same size,and the one I have has "progressive butterfly's" one set opens first.I guess what I'm asking is what is the difference between a 150 and a 225 throttle body.I have the correct seven petal front.Also are the air boxes all the same?
11-26-2015, 02:43 AM #2Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
no sir they are all identical except for the ones that were on the very first efi 2.4 they had butterflys that both opened at same time some of these newbies swore they had the deal of a century but ive not found any super deal with the very old first attempts stuff if it was all that it would not have changed" air box" as in yer carbing the lil fellow awh too bad
11-26-2015, 06:32 AM #3
11-26-2015, 08:10 AM #4
"The air box" Is what I'm calling the cover that seals over the top of the injection body,makes it airtight.
11-26-2015, 08:47 AM #5
that will make 'em (bobby) feel better....has he ever mentioned how much he dislikes CARBURETORS! Ha!
11-26-2015, 12:11 PM #6
Years back there were a couple places that would bore the throttle plates and install larger butterfly's. Not sure if they worked any better.
11-26-2015, 01:32 PM #7
Thanks Dave,I'll be happy to get it turn key,and make noise.This is my first venture into TB injection.
11-26-2015, 01:51 PM #8
If your going to play with Laser EFI get the TPS adjusting tool they are cheap and best way to adjust the TPS.
11-26-2015, 01:52 PM #9
It's only called an air box if u drilling holes in the front and add carb butterflies
11-26-2015, 02:02 PM #10
Dave,will be using a Brucato PCU,Texas,sometimes it where ya come from that determines what ya call sumpin.Jacki Wilson,may call it a bonnet of sorts! Anyway that damm thing that bolts to the front and makes the air come in from the rear.
texasvector liked this post
11-26-2015, 06:10 PM #11Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
we call it what merc calls it plenum cover
11-26-2015, 06:33 PM #12
that "thinga me jigger" on da front a dat der mota
HAPPY THANKSGIVING GUYS!!!81' HYDROSTREAM VECTOR / slightly Modified 200
11-26-2015, 06:35 PM #131980 Cougar 19 tunnel,90 2.4L Bridgeport EFI in middle of restoration.
Efi throttle body
By skatermike24 in forum Misc. Parts and AccessoriesReplies: 6Last Post: 10-22-2015, 02:30 PM -
Throttle body
By shep70057 in forum Technical DiscussionReplies: 3Last Post: 03-26-2005, 12:20 PM
