Results 1 to 10 of 10
    Jul 2004
    Connecticut
    PVS Hole Machine - Shop Wanted
    I need PVS vent holes installed in a non Merc prop. I thought I had read years ago that some shops have a machine that can cut true PVS holes into any prop so that you can then use the Mercury plastic plugs to tune the prop.
    Anyone know which prop shops might have this capability? Has anyone had this done to one of there props? Thx for any feedback.
    Ft. Lauderdale, Fl
    Any good machine shop can do it if you give them the dimension and location.....
    Jul 2004
    Connecticut
    Quote Originally Posted by flabum1017 View Post
    Thanks but candidly I'm a luddite with that type of thing. I think there is a shop out there that has tooling that will cut a perfect PVS hole to accept the plastic plugs. Hoping to find that outfits name and location.
    Jul 2004
    Connecticut
    I'm assuming that the various Mercury PVS plastic plugs are all the exact same diameter and have the same snap
    Sep 2011
    Quitman, TEXAS
    most big prop shops have the mills, and the correct bits to do them.
    steves custom props
    croxton
    tillmans
    SCP charges 15.00 per hole to do them.
    a true machine shop will be much higher as their labor rates are really high.
    98 XR2001 Drag w/pro stock mota
    Aug 2012
    MS
    Jul 2002
    Las Vegas, NV
    Kevin @ R&R Prop shop put the PVS holes in my Bravo 1's. 702-564-7502
    Keith-
    Jul 2004
    Connecticut
    Thanks guys for the info.
    Aug 2004
    Venice, Florida
    Hydromotive can do it. They did one for me.
    21' Paramount
    Mercury 300 Promax
    Aug 2004
    Venice, Florida
    Yes.......
    21' Paramount
    Mercury 300 Promax
  1. Machine Shop Seattle
    By ringstad in forum Technical Discussion
    Last Post: 01-31-2013, 01:31 AM
  2. Machine shop
    By 2.4 in forum Technical Discussion
    Last Post: 01-29-2008, 07:12 PM
  3. Hello from Bob's Machine Shop
    By Steven@BMS in forum The Scream And Fly Lounge
    Last Post: 01-04-2008, 04:25 PM
  4. Impellers from Bob's Machine Shop
    By Markus in forum Technical Discussion
    Last Post: 04-16-2002, 05:59 PM
  5. machine shop
    By charger19 in forum Technical Discussion
    Last Post: 10-25-2001, 05:36 AM
