Results 1 to 15 of 17
    Jun 2010
    Clearwater,FL
    Dirty Etec injector cleaning
    Took the fuel manifolds off my 250 etec injectors and this is what I found in there. I was told it was dried up and crystallized ethanol fuel. (the motors have been sitting in storage for nine years) The only thing that seemed to even touch the stuff was some Mercury power tune.
    I took them to Florida Injection in Pinellas Park. They said they have seen it before and are going to clean them up for me.
    Mar 2007
    Ontario, New York
    The inside of the VST most likely looks the same. I'd give the entire fuel system on that motor a good cleaning/going through! FYI you can pull the injectors out of their housings, they are just held in by o-rings...
    Dan Cario
    1994 STV Mod-VP w/225HO Ficht Evinrude
    1987 22' Velocity w/225HO Evinrude E-Tec
    Damm cat piss fuel.
    May 2001
    Hickory NC
    If the inside of the cup shows corrosion when removed you may end up needing to replace the injectors.
  5. Likes baja200merk liked this post
    Aug 2012
    beaumont, tx
    Quote Originally Posted by Baja16 View Post
    baja......that modvp is bad ass!!! more pics please.....on other thread...sorry for high jack
    Jun 2010
    Clearwater,FL
    I tried removing an injector from a cup but it didn't want to come out. I didn't spend much time messing with it since I was taking it to the injector company. I didn't notice any of this junk elsewhere in the fuel system but I plan on checking it all over carefully. The bummer is a couple of the plastic nipples of the fuel manifold and brp is mighty proud of those.
    Just buy a used fuel manifold on ebay
    Sometimes you can block off the return port and use air pressure to pop the injector apart. Or if you make a little plate with a couple bolts U can use it as a puller. You don't have much to lose.
  9. #8
    Jun 2010
    Clearwater,FL
    The little puller is a good idea... I just tried using a slide hammer on one while just holding it... Like you said nothing to loose.. been watching some parts on Flea bay.
  10. #9
    May 2006
    Be sure to replace the vapor separator tank return line filter also.
  11. #10
    May 2001
    Hickory NC
    Remember injector flow rates are matched to the EMM
  12. #11
    Jun 2010
    Clearwater,FL
    Yes I marked each injector tag with it's cylinder number so I put them back where they came from. Of couse if I have to replace any of them I will have to update the emm with the coefficients.
  13. #12
    Id guess your gonna end up with a couple that don't work. I can read the qr code and change coefficents to match whatever injector you change it to. Old voice coil are easy BIP get interesting.
  14. #13
    Jun 2010
    Clearwater,FL
    I agree Kevin. I tested the resistance of the injectors and all except one tested ok. Injector #1 tested open so I think the voice coil is bad in that one. Hopefully I'll find out this week.
    Marine rebuilders cleaned up my rods and said they may or may not be usable. I'll pick them up and see what you think of them Kevin.
  15. #14
    I'll help however I can. The motor has potential no doubt it can be fixed.
  16. #15
    May 2001
    Hickory NC
    If they dont know the rods are useable they should not be cleaning them up. If the rods have pits in them I would not use them, not worth taking a chance. You should also check cap alignment.
  1. injector cleaning
    By v-kinger in forum Technical Discussion
    Last Post: 02-02-2014, 10:19 AM
  2. Injector Cleaning and Calibrating...
    By tony1204au in forum Technical Discussion
    Last Post: 08-03-2012, 06:55 PM
  3. Injector Cleaning?????
    By beer30 in forum General Boating Discussion
    Last Post: 04-11-2008, 12:15 PM
  4. injector cleaning
    By TEXAS20225 in forum Technical Discussion
    Last Post: 05-30-2007, 10:02 PM
  5. 2.4 Injector Cleaning
    By racer-x6 in forum Technical Discussion
    Last Post: 07-22-2003, 07:04 PM
