Results 1 to 15 of 31
Thread: Vertex or Wiseco?
11-08-2015, 06:09 PM #15000 RPM
- Mar 2009
- Seymour, Tn
- 176
Vertex or Wiseco?
What do you guys prefer and why?
11-08-2015, 06:10 PM #2Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Wiseco, lighter stronger faster. Coated
11-08-2015, 06:16 PM #3
siezeco is good if you run them loose and put some break in time on them. vertex has a better reputation from what i have read in the forums.
11-08-2015, 06:27 PM #45000 RPM
- Mar 2009
- Seymour, Tn
- 176
Actually the Vertex is lighter. 473 grams
11-08-2015, 06:36 PM #5Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Can't say for all application, I save near 1/4lb reciprocating weight plus crowns are coated. Yes break in is slow and deliberate.
11-08-2015, 06:43 PM #65000 RPM
- Mar 2009
- Seymour, Tn
- 176
Where are you saving weight?
11-08-2015, 07:19 PM #7Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Total piston weight, which is part of the reciprocating weight.Recip being piston, pin, clips, rings, rollers, and small end of the rod.
Where did you save over a pound? In may case Wiseco is significantly lighter than Vertex.Last edited by FMP; 11-08-2015 at 07:45 PM.
11-08-2015, 08:09 PM #8Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Wsm has been good for us,Chris
11-08-2015, 08:48 PM #95000 RPM
- Mar 2009
- Seymour, Tn
- 176
I have a Vertex and Wiseco piston, complete with wrist pin and rings and the Vertex is much lighter. I have never used the Wsm, Chris. What do you like about them?
11-08-2015, 08:50 PM #105000 RPM
- Mar 2009
- Seymour, Tn
- 176
What motor are you building, FMP?
tux974 liked this post
11-08-2015, 10:04 PM #11Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
A lot depends on the engine, power level and rpm.
11-08-2015, 10:33 PM #125000 RPM
- Mar 2009
- Seymour, Tn
- 176
The reason I am asking is I have always used Vertex and they are on back order at Pro Marine. I was building a motor the other day (225pm) and noticed a big difference between them. I looked on ProMarine website and the Wiseco is advertised at 1.6 lbs and Vertex at 1.5 lbs.
11-09-2015, 06:44 AM #13
Good and important question!
This will tell all for me!
For a stock 225PM or around 7000ish+/- the Vertex is an excellent choice. Been using them in plenty 225PM motors will exceptional results.
Even the ProV is a good piston. For me a steel bore motor get cast pistons.
I have never tried the WSM that Chris mentioned, just may try a set in the near future. I think the one advantage is the 1.5 rings.
11-09-2015, 06:58 AM #14
i just put a set of wsm's in a 3 litre, they seem like a decent piston. never had good luck with the wiseco's(at least in the mercurys), thanks for the tip chris, the wsm seems like a nice piston. vertex are great when you can get them, pro stopped carrying them for 3 litre mercury applications. i personally would run a wsm if the vertex weren't available.
11-09-2015, 07:11 AM #15
For a PM, WSM is the best choice. Top quality cast piston coated and comes with 1.5MM rings like the factory...Vertex are good but use the 2 mm ring. I have several PM w/ WSM pistons and they run great and never had one problem. WSM also offer oversized pistons for the PM with 1.5mm rings.
Go Time
26 Regulator twin 250 EFI
Vertex?
By tlwjkw in forum Technical DiscussionReplies: 2Last Post: 10-07-2009, 08:40 PM -
Vertex?
By tlwjkw in forum Technical DiscussionReplies: 2Last Post: 09-09-2009, 07:13 PM -
vertex pistons
By rick#17 in forum General Boating DiscussionReplies: 1Last Post: 08-29-2009, 03:50 PM
