Results 16 to 30 of 38
    Dec 2006
    Chesterfield Twp, MI
    I needed to run new power lines out to my garage and bar room last week so van work was placed on the back burner.. But I was able to get a few good hours of work done this weekend.
    I used left over rubber flooring glued to the walls to help reduce scuffing and normal wear and tear.
    Built in tool boxes trimmed out
    Lounge door installed and trimmed out with 2" aluminum flat stock used for carpet transitions.
ID:	331687 Click image for larger version.
  2. #17
    Dec 2006
    I had rubber flooring on the tool box bench, but removed it for the while plastic walling. All black walls really seemed to dark and shrunk the already small space.
    I wanted stainless counter tops, but after I was given a price I changed to aluminum.. much cheaper and a little lighter, not like that matters in the big picture.
ID:	331689Click image for larger version.
  3. #18
    Dec 2006
    Electrical run on the main work work counter with shelf installed. I'm pretty happy with the overall looks at this time.
ID:	331807Click image for larger version.
ID:	331808Click image for larger version.
ID:	331809Click image for larger version.
  4. #19
    Jun 2012
    Bainbridge, Ga
    Your rig is coming together nicely! Great job
    Flint River Mafia
    1983 Laser LTV #007 RIP Lloyd Burns
    1994 Mirage RR "The Purple Drip" SOLD
    2002 Laser LTV "SOLD"
  5. #20
    Dec 2006
    $16 bucks for LED light tape off ebay, and $40 for LED installation aluminum channel... not bad.
    <iframe src="https://www.youtube.com/embed/N6ZlfLLE5_k" allowfullscreen="" frameborder="0" height="315" width="560"></iframe>
  6. #21
    Dec 2006
    I found the plastic storage bins like the NASCAR rigs use on Ebay, pricey.. but worth it. One of the best prices I found was 112 bins for $116.00 (free shipping), right around 1$ per bin.
    Not really bad, but considering the size of the bins I would need a couple hundred bucks worth.
    But while looking online I found this plastic case from Harbor freight for 8.99 with 20 removable plastic bins. Thats .45 cents each, seemed a little thicker, a littler deeper to hold more parts and has a Plastic case I can use as a goggle box or maybe GoPro camera box once I cut a piece of carpet for the bottom.
    Over all not bad. Every company make there tool boxes a little different so I used skid plate foam cut around the back and one side to fill in extra space and to keep the boxes snug. These are just 4 draws, but offer lots of storage for stainless steel hardware, pumps, impellers, wire..etc.
    1/2 the price...
  7. #22
    Very cool set up Pachanga!
  8. #23
    Apr 2002
    Wrong Irand, NY
    Great Job so far
    Formula 260ss 496HO
    Bender Clan Member
  9. #24
    Dec 2006
    Working on the Ok' from the wife but the rig might be forsale for something a little larger, more comfortable and will hold the boat INSIDE.
  10. #25
    Dec 2006
    The LED's lights are wired to a large marine battery in one of the cabinets along with a REALLY BRIGHT halogen 110v light for when I might need some serious light. The back is finished.. now I'll start on the front.
  11. #26
    Dec 2006
    After a mid winter break I'm back to work.. I cut the hole this weekend to access the cab, I was going to buy a rubber accordion seal but after talking to the body shop guy at General RV I'll be doing something different. His words " Every Class C RV and Most Ford Cube truck have the cab bolted to the chassis" it wont twist, if it does you bent your frame and will have bigger issues.. The advantage for me is only cosmetic, a rubber seal wont look as nice..
    Also most people don't like the a table/bed combo and would prefer a couch. So I punted and will install a couch.. one problem I ran into is finding a couch small enough to get into the area and threw a 24" door way.
    Problem solved (i Think) I found a 74" W couch for 169.99, but its short.. so I'll cut off the legs and build a base from Overhead kitchen cabinets to raise it up to normal tall people height. This will also add a little more storage..
  12. Likes Frank Molé liked this post
  13. #27
    Dec 2006
    RV Panel is up and glued into place. I also used the plastic snap pieces between the planes for a clean finished look.
    Upper crown molding is 9" chip board with carpet glued on. Each piece is 4ft long and attached with screws to a wood block that was fastened to the box. This way I can remove it to run my lights or to install speakers.
    Between the doors I had a funky size gap that would have been difficult to finish, so I wrapped some carpet and screwed it in.
  14. #28
    Dec 2006
    Total cost including the truck and mechanical repair is around 4k so far.
    I bought CHEAP carpet with padding already attached (.64 cents) sqft
    from Menards. It was thin enough to roll around round corners yet has a
    little insulation and sound deadening properties.
    The thin trim board is nothing more than OSB with the carpet stapled to it.
    The reason I need todo this was the corners are metal so to cover them I
    need wider wood to reach over to the box area.
  15. Likes mrichartz, Frank Molé liked this post
  16. #29
    Thumbs up
    coming out great,wow nice job and lots of thinking...
    TRANSPORT SERVICE...UP TO 36 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
    DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY.
    LIVE LIFE ON THE EDGE, LESS CROWED BETTER VIEW
  17. #30
    Jul 2002
    Copiague LI NY
    Wow.....thats comin out awesome....makes me wanna do something similar but set it up as a mobil shop....keep up the great work....
    1984 28 ghost twin 200 Yamah ProVs (SOLD)
    1997 21 Superboat Legend 250 VMAXXX (SOLD)
    2001 25 Concept CC 250EFI (SOLD)
    2002 24 Superboat Step 250EFI (SOLD)
    1997 21 Checkmate Pulsare 200EFI Merc (Beater Boat)(SOLD)
    1994 20 Hydrasport 225 Optimax (SOLD)
    1998 27 progression Twin 225 Mercs (SOLD)
    2005 23 Kryptonite 300 Promax (SOLD)
  1. Help me build a budget flats boat with Merc power
    By Capted in forum Bass Boats and Sport Fishing Rigs
    Last Post: 03-28-2015, 08:32 PM
  2. 2010 e350 super duty ford 15 passenger van
    By Baitman in forum Tow Vehicles and Trailers
    Last Post: 08-10-2014, 07:52 AM
  3. Mercury Tech: Budget 150 build with hypereutectics
    By wired247 in forum Technical Discussion
    Last Post: 10-18-2013, 01:55 AM
  4. 100 MPH Valero budget Build (The Nightmare)
    By Jamescole in forum General Boating Discussion
    Last Post: 05-29-2013, 11:43 AM
  5. 2000 Ford E350 Diesel Van with Crew Seating Package
    By hans_a in forum Tow Vehicles and Trailers
    Last Post: 08-31-2006, 08:26 AM
