Results 1 to 3 of 3
Thread: prop types
    Bayville, New Jersey
    prop types
    Performance difference between a Drag 4 and a Pro ET ? The blades appear very similar, will one give more bow or stern lift or wind up faster or ?
    Thanks
    Prince George B.C. Canada
    Im going to say no two props are created equal and it all depends on your setup as to whats going to work best for you. i know a drag 4 has great stern lift and has even more with a little tip cup for instance. The pro et much the same. Never tryed a BBlades but I know heavier bass boat guys love them so they must have good lift also. Pitch ,Rake, Diameter, skew, Over/ under hub gearcase rpm,load and hull all play a factor. On what setup?
    Thanks, 21 Skater 300 PM.
  1. prop shaft height with regards to specific types of lower units.....
    By Csmyj in forum Props, Setup, and Rigging
    Last Post: 02-28-2014, 02:17 PM
  2. stv types
    By Bdusted440 in forum General Boating Discussion
    Last Post: 12-19-2011, 03:19 PM
  3. ECU types
    By Techno in forum Technical Discussion
    Last Post: 05-02-2001, 08:12 PM
Diamond Marine
