Results 1 to 13 of 13
Thread: 2.5 245 carb cutting heads
11-03-2015, 08:43 AM #15000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
OK guy's time to bump it up some, want to up the HP on the old 245, comp is 129 the rest is 134-6 leakdown 4-7%, want up comp as much as I can looking at using aces to mix with 91-93 octane can't get non ethanol premium here, recommended free comp please. Thanks
11-03-2015, 12:36 PM #2
Ran 34cc on my 245hp at 3000' on non ethanol 92, had 145psi. would think 34 would be safe.
11-03-2015, 03:54 PM #35000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
I know I would have to run 93 and aces all the time but thinking 160
11-03-2015, 03:56 PM #4
Are u gaining enough to make the risk worth it?
U draging it?
edit...^^^i agree with the 34 ....asking about the 160Last edited by texasvector; 11-03-2015 at 04:47 PM.
11-03-2015, 04:39 PM #56000 RPM
- Aug 2011
- ct
- 1,017
- 12
- 65
We all run 34cc on ours Motors and it seems to work out well
11-03-2015, 10:15 PM #6
34 with 1 mm gasket
11-03-2015, 11:16 PM #7
Would it be OKAY if he would shave the heads a little more and include the 1mm of the gasket into the shaving ??
Glastron GT 150 W OMC 140
Glastron GT150 w OMC 235
Hydrostream Vision with 2.0l 135
Hydrostream HST w 3.0L 225
I know two things that are infinite, the Universe and Human's Stupidity, although I am not sure about the first one.
11-04-2015, 11:08 AM #85000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
Hell I don't know that's why I'm asking the guru's on here, like everybody here never enough hp, I seen jay Smith's evaluation of aces and was impressed, just want more hp figured cut head was best way, I've got 1" spacer,CC reeds already,
11-04-2015, 11:13 AM #9
I ran 175-180 #'s on my 260 for over a year with aces, klotz and GOOD 93 octane. Personally I didn't see enough difference from 140-180 to justify the stress on my motor. Still running the aces but running 140 pounds of compression and a few stages of nitrous now
1992 STV River Rocket - bottle fed 260
11-04-2015, 12:22 PM #1081' HYDROSTREAM VECTOR / slightly Modified 200
TripleA liked this post
11-04-2015, 12:55 PM #115000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
I'm not racing now but maybe later on, just would like some cheap hp, figured 160 wouldn't be too bad maybe 150, just checking out options before biting bullet
11-04-2015, 01:05 PM #12
Healthy motor at sea level will be real close to 150psi with 34cc. Rarely seemuch top end gains but make a big diff in the mid range, also seem to start and idle better.
11-04-2015, 01:40 PM #13
I've been running my 245block with stock porting and 34cc heads for years on 91 with no issues at 300ft above sea level.
Run it a little fat and don't go nuts on the timing.
With the block decked probably 18 thou or so I make roughly 150-155psi on my testerLast edited by P man; 11-04-2015 at 04:55 PM.
texasvector liked this post
cutting heads
By old ranger in forum Technical DiscussionReplies: 9Last Post: 05-09-2006, 03:37 PM -
Cutting Heads
By Glasply150 in forum Technical DiscussionReplies: 6Last Post: 10-11-2005, 11:12 PM -
Cutting Heads
By Glasply150 in forum Technical DiscussionReplies: 1Last Post: 10-02-2005, 01:48 AM -
cutting heads
By daytrader in forum Technical DiscussionReplies: 6Last Post: 07-11-2004, 11:59 AM -
cutting heads on a 150 omc
By sixabove in forum Technical DiscussionReplies: 0Last Post: 01-21-2002, 09:10 AM
