Results 1 to 10 of 10
10-23-2015, 07:10 PM #1
Parting out twin 1987 225 Evinrude 2.7 Bridgeports
Make offers want this stuff to go to new homes.
Ebay listings: http://m.ebay.com/sch/i.html?isRefin...hydrostream2.5
HEADS ARE SOLD
All electronics good. These were good running engines that ended up having underwater corrosion issues with the brackets and trim manifolds.
1 OEM Stator left
Power packs are good one new last year 4 more available. All are 6700 rpm. I think I have a 5500 RPM powerpack too. This is the two power pack style ignition.
2 crankshafts look to be in excellent condition.
VRO Tank
Vacuum Switch (2)
Intake manifold (2)
Throttle bodies (2)
Carb links (2) - the ones found at the top of the carbs that often have a play in the barrel where it pushes on the linkage.
Regulator
2 keyswitches and alarm buzzers (used one season bought new)
Spark advance levers
Electrical bracket olastic piece found at top rear where connecting panel resides
Top crank cap with good bearing (2)
Air Silencer cover (2)
Air silencer base (2)
05-29-2016, 07:32 AM #2
Link to my ebay:
http://m.ebay.com/sch/i.html?sid=hyd...&isRefine=true
06-14-2016, 06:03 PM #3
Anyone want the cowls, free, want to clear out some space in my loft.
2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
06-20-2016, 02:48 PM #45000 RPM
- Nov 2013
- PA
- 147
Hello, are the vro pumps the same as brp part number 5007420? If so, how much shipped to zip code 16117? Thanks, Paul
06-21-2016, 09:15 AM #5
06-22-2016, 08:56 PM #6
Accepting offers just make it worth my while to ship this stuff so it goes to a new home.
06-23-2016, 10:20 AM #7
I could use a center main bearing cap and retainer. How much?
06-23-2016, 11:03 AM #8
06-24-2016, 09:13 AM #9
The center main bearings are on the crank in the center of the shaft. You have the upper pictured
06-24-2016, 12:11 PM #10
By at100plus in forum Misc. Parts and AccessoriesReplies: 0Last Post: 10-09-2015, 09:34 AM -
Eliminator Daytona 23 w/twin 2.4 Bridgeports Beauty!
By noli in forum Ebay Listings and Other Internet ListingsReplies: 5Last Post: 09-12-2015, 05:46 PM
