Results 1 to 3 of 3
10-17-2015, 04:14 PM #1New Member
- Oct 2015
- Finger Lakes, NY
How to winterize 455 olds/Berkeley Jet/Nicson Manifolds
Trying to figure this out, coming from stern drives.
My hot-rodded (by others) Rally Sport Hombre has a water valve, then a spigot coming from the right side of the berkely at the transom. From there it tees to the front of each Nicson manifold.
I tried closing the valeve from the jet drive transom and [gravity] feeding RV antifreeze into the spigot, but only a little went in (and none seems to have come out!?).
I'm guessing that the jet feeds the water jacket by way of the manifolds (which seems backwards), and then the water dumps into the back part of the manifold?
Am I going to be able to gravity-feed antifreeze at all? Can't figure out any other way.
HELP! Feezing weather is here. Had the boat for a couple weeks only.
Thanks,
11-15-2015, 06:50 PM #2New Member
- Oct 2014
- Montana
Why don't you just drain everything so you are sure?
Ken.........
11-15-2015, 09:12 PM #3
Drain 1st block exh and all hoses get out as much water as you can then you need to pump non toxic anti freeze in with a wash down pump or jabsco puppy pump or somthing while it's running treat fuel and fogg with marlvel mistory oil
good luck
03 j17 skiff 40hp
79 action 17 2.4
79 15 viper (sold)
85 22 velocity 225efi(sold)
82 31 sea ray
Nicson or ???
By mbeard007 in forum Technical DiscussionReplies: 3Last Post: 08-11-2009, 09:05 PM -
Poll....To Winterize or Not to Winterize in North Carolina???
By motoxconnection in forum General Boating DiscussionReplies: 10Last Post: 10-17-2006, 11:29 AM -
Nicson Marine still around?
By WS6_Keith in forum Technical DiscussionReplies: 3Last Post: 04-16-2002, 10:23 PM
