Results 1 to 15 of 16
Thread: Fuel and bleed hoses
10-01-2015, 11:46 AM #15000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
Has anyone tried the motor cycle type polyurethane hoses for fuel and bleed circuits on a carb motor.
10-01-2015, 12:34 PM #25000 RPM
- May 2009
- Myrtle Beach
- 99
I used the yellow/clear fuel lines on my 2.4 200. Only been running it a month now since it went back together but so far no problems. You can see the fuel/oil mixture pulsing through the lines.
10-02-2015, 05:47 AM #35000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
Where you buying the yellow clear?
10-02-2015, 06:01 AM #45000 RPM
- May 2009
- Myrtle Beach
- 99
I bought it at a local hardware store that has bulk rolls and sells it by the foot. It's called Tygon fuel line. I used it for my bleed lines and prime lines. I don't think it is labeled for marine but is said to be safe for gasoline as well as alcohol blends. Here is an example.
http://www.ebay.com/itm/10-Ft-Tygon-...-/230942031653
10-02-2015, 06:35 AM #5
If you use the clear tygon (yellow tubing), make sure you tie-wrap them to the fittings. That tubing will get soft when the engine is warm and may come off the fitting barb.
Go Time
26 Regulator twin 250 EFI
10-02-2015, 07:22 AM #65000 RPM
- May 2009
- Myrtle Beach
- 99
I did that. Don't know how well it will do in the long run but it was nice to be able to see the mixture moving through the lines when I fired it up. You can tell if you have a bad or clogged check valve. I also used the clear tubing with the braiding in it for my water lines coming off the thermostats.
10-02-2015, 08:50 AM #7
i did the same on my175 efi on my bass boat,they have held up great.ive run them for over a year now with no issues and i run the sh*T out of it.you definitely need to use zip ties on all the connections,found this out the hard way!
tux974 liked this post
10-04-2015, 04:05 PM #85000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
Thanks for the replies everyone. Looks like the Tygon hose is worth a try!
10-10-2015, 11:20 AM #95000 RPM
- Aug 2008
- Stoneville NC
- 677
Only issues I find and I build about 10 to 14 engines a year in my shop and lots of small repairs as well.. so I see quiet a bit of tygon used.. that being said it does get soft when warmed up so use tie wraps of something to clamp it well. The other issue is it becomes hard and brittle as it ages and if it still is holding maybe OK but I replace it.. myself I use marine fuel grade hose from Pro Marine on my personal engines and on customer engines as well unless they specifically want Tygon.
20ft Gambler with Merc 260
Too many projects to liist..
10-10-2015, 03:58 PM #10Glastron GT 150 W OMC 140
Glastron GT150 w OMC 235
Hydrostream Vision with 2.0l 135
Hydrostream HST w 3.0L 225
I know two things that are infinite, the Universe and Human's Stupidity, although I am not sure about the first one.
10-10-2015, 09:25 PM #115000 RPM
- Aug 2008
- Stoneville NC
- 677
Engine sneeze is from too lean at cold idle.. Anyway long story short I rather have rubber fuel grade stuff. Tygon is mostly used for weed eater fuel hose.
10-10-2015, 10:40 PM #12
if you get correct size tygon for the barb you don't need zip ties ,I only had 1 line come off in 12 years and that's because I pulled it off and put it back on and did not cut off 1/2 inch
10-13-2015, 10:57 PM #13
Eli your right i also use the red/pinkish tygo from ace hardware works great 3 dif .sizes
02 mirage ski racer w/ 2.5
lake tarpon (LTB racing)
"Mirage Boats... often imitated but never duplicated"
10-18-2015, 05:38 AM #14
The Tygon hose used is "Tygon 4040" and yes it is not very heat tolerant.
Regards,
Charlie North
If it ain't broke, modify it.
87 Glastron CVX20 Hull
10-18-2015, 12:45 PM #15Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
most merc bleed bibs use 3/32 hose,aint tygon is 1/8
Mercury Tech: bleed hoses leak!
By Procraft 180 DC in forum Technical DiscussionReplies: 8Last Post: 05-28-2009, 12:30 PM -
bleed hoses
By oneshot in forum Technical DiscussionReplies: 10Last Post: 03-06-2008, 12:32 PM -
bleed hoses
By xstream in forum Technical DiscussionReplies: 3Last Post: 09-15-2006, 10:14 AM -
where to buy bleed hoses/targon
By eli in forum Technical DiscussionReplies: 4Last Post: 07-23-2004, 08:14 AM -
Bleed hoses on a 2.4
By horn5413 in forum Technical DiscussionReplies: 0Last Post: 06-21-2004, 07:23 PM
