Results 436 to 450 of 622
06-26-2016, 05:50 PM #436
"Timing set to 136* btdc." Is that a typo? Not sure what it should be but most are set in the low 20* area especially with increased compression.
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
06-26-2016, 07:07 PM #437
Sounds Great!!!!! Good luck tomorrow and can't wait for some news after the test run!!!! Gary
06-26-2016, 10:20 PM #438
06-27-2016, 05:56 AM #439
Oh come on and I thought it sounded so good because you had the stones to timer up!!!! lol Gary
06-27-2016, 06:22 AM #440
HA ! Ok ok ok - I'll go 136* ! ! ! Zoom Zoom Boom ?! I don't think it would even Idle at that setting haha.
I did have to yank the flywheel off to get the timing right because I aligned the stator a bolt hole off - I could only get 10* advanced at the farthest setting on the trigger. Yanked the flywheel, clocked the stator another bolt hole, and voila... all better haha.Last edited by home made tunnel; 06-27-2016 at 07:46 AM.
06-27-2016, 07:54 AM #441
Did you mark TDC on the flywheel for all 3 cylinders and set timing from the one that read the most advanced?
JamesJames H. W2F a V-King... Want 2 Fly a V-King
06-27-2016, 11:12 AM #442Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Use the NGK . http://www.marineengine.com/newparts...m=MER1395-6207
If you start wit these you can drill them out. Or try the jets from a 105 Chrysler .086 .084 but that will be too rich. Check the plugs again after a few hrs. Fresh fuel good oil and psi will show .Last edited by FMP; 06-27-2016 at 11:14 AM.
06-27-2016, 12:00 PM #443Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
06-27-2016, 12:05 PM #444Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
06-27-2016, 01:49 PM #445
06-27-2016, 03:06 PM #446
Need Number drill bits #47, 46, 45. Chart link..
http://7id.xray.aps.anl.gov/tables/number_drill.htmlLast edited by Robby321; 06-27-2016 at 03:08 PM.
Slimm liked this post
06-27-2016, 06:27 PM #447
Ran it today- runs fine on the driveway but like poo in the water at idle. I need to do the idle air jet adjustment all over again.
So it has Way more power it feels like. I just cruised around a bit and it is no effort at all to hit 5krpm- like wayyyyy easy 1/3 throttle. So I still need a bigger prop and prob better gears.
Heres the plugs-cyl 1 is lightest. Cyl 3 is darkest. (Also the one that fried before.) I haven't checked each chlinder to see which is most advanced yet.
06-27-2016, 08:32 PM #448
On the plugs?
First plug could use bit more gas, as second look pretty normal to me but maybe a tad rich. Last? Thats REALLY needing gas! Need some "chocolate brown" insulator like #1. Just my dumbass opinion...........
Capt.Insane-o liked this post
06-28-2016, 05:09 AM #449
Just an FYI- that pic with all thre in it that says lean rich and normal, those aren't my plugs. Just for reference lol
06-28-2016, 07:17 AM #450Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
YOU don't want a repeat of #3 so try to check the timing , try a little bigger jet in #3 than the rest . What is could be is the ex port size you now have and the ex mix that is getting into #3 from the stuf before close and the heat from that, but haven't seen it on #4 on the L4.
Never mind Quints
By Wayne Cammidge in forum General Boating DiscussionReplies: 0Last Post: 02-19-2015, 05:29 AM -
Mind if I vent?
By QUICKSILVER in forum The Scream And Fly LoungeReplies: 12Last Post: 10-21-2003, 10:22 PM -
Keep An Open Mind
By mr.clean in forum The Scream And Fly LoungeReplies: 0Last Post: 10-09-2003, 12:23 AM -
Tell me if I'm out of my mind!
By cdaspeed in forum Props, Setup, and RiggingReplies: 2Last Post: 08-26-2003, 09:31 AM
