Results 1 to 3 of 3
Thread: MAP sensor
09-15-2015, 09:40 PM #1
MAP sensor
My 225 Opti max will not idle correctly under 1000 RPMs and stalls frequently. At above 1000 RPMs it seems to run normal. I changed plugs, no help. Dealer checked and gets a MAP sensor "bad" light. I know nothing about these new computer driven monsters and we plan on installing a new sensor. Also got a throttle body sensor light once but then it went away. The cam on the throttle spark mechanism seems worn????? Any hints? Wish I had my max's with carbs back.
2jz thanked for this post
09-16-2015, 10:41 AM #25000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
Replace map sensor first should correct your problem. Without map sensnor ecm uses tps for fuel corrections to run motor. Map sensor is right behind throttle body one bolt and one plug connection.
09-16-2015, 11:21 PM #3
Thanks for the quick answer, will try and let you know.
Identifying this sensor on 2001 300x, knock sensor?
By turbo94gto in forum Technical DiscussionReplies: 2Last Post: 04-11-2013, 11:14 PM -
Mercury Tech: ait sensor/mass air flow sensor
By ddantidwell in forum Technical DiscussionReplies: 3Last Post: 03-27-2011, 10:59 PM -
260 Air sensor.
By chad202 in forum Technical DiscussionReplies: 4Last Post: 08-20-2005, 07:41 PM -
Ecu Sensor
By ALLAN D in forum Technical DiscussionReplies: 3Last Post: 08-13-2003, 02:45 PM
