Results 1 to 8 of 8
    Apr 2013
    Lexington, ky
    Rings for one cylinder?
    I need rings to pop a single piston in...all I can find is whole sets. Who sells rings for individual pistons?
    Stock bore, stock piston 99 Merc 2.5 200 serial OG869690
    ​Slimm
    Nov 2002
    Lake Lanier - Atlanta, GA
    Lots of partial kits on ebay all the time...
    http://www.ebay.com/sch/i.html?_from...21a12&_sacat=0
  3. Likes Slimm liked this post
    Apr 2013
    Lexington, ky
    Quote Originally Posted by 25XS View Post
    Thanks bud. I was hoping to spend money with a friend on the board, not ready for the ring today so guess I'll give it a day or two and hope someone sends me on the right path.
    Slimm
    Dec 2012
    tn
    Ok - I will ask- are you putting a used piston back in with new rings on that one used piston? Is the used piston good enough to risk the block over a $100.
    New pistons normally come with rings.
    http://promarineusa.com/
    2MM ring set #321
  7. Thanks Slimm thanked for this post
    Aug 2009
    mpls,mn
    pm sent
  9. Thanks Slimm thanked for this post
    Sep 2006
    Key Largo, Fl
    Slimm,your rings are ready to ship...need your address,check your pm;s,Chris
  11. Thanks Slimm thanked for this post
  12. #8
    Apr 2013
    Lexington, ky
    Thanks Chris, I am in the process of trying to clean it all up and make sure I can pop a piston and go without needing to rebore.
    As soon as I confirm I'll get things ordered.
    Slimm
  1. Dual cylinder hydraulic vs single cylinder on a single engine application
    By 1BadAction in forum Props, Setup, and Rigging
    Last Post: 07-11-2015, 03:42 PM
  2. OMC Tech: GT-150 needs to piston, rings, cylinder work? Need advice!
    By imq707s in forum Technical Discussion
    Last Post: 04-07-2010, 12:14 PM
  3. 260 rings can i use chrome rings
    By jgiroux in forum Technical Discussion
    Last Post: 07-02-2009, 09:54 AM
  4. good rings - bad rings
    By roadkill636 in forum Technical Discussion
    Last Post: 04-02-2008, 05:25 PM
  5. piston rings & crank sealing rings
    By TB21 in forum Technical Discussion
    Last Post: 12-19-2001, 08:49 PM
