Results 1 to 15 of 16
    Aug 2006
    St. Louis, MO
    Pro Max 225 identifying power head HELP
    I am looking to buy a 225 pro max. Just want to make sure I am buying what the the seller is describing. Can you tell what this is off the pictures?
    Attached Thumbnails Attached Thumbnails image.jpg   image.jpg   image.jpg   image.jpg   image.jpg
    MIAMI FLORIDA
    Not a 98 powerhead.
    Aug 2006
    St. Louis, MO
    Quote Originally Posted by H2OPERF View Post
    Not a 98 powerhead.
    I don't know what it is. Just attempting to figure it out.
    TX......somewhere?
    could be a "painted 225 PM block".. other than tha 260/280, its tha only one that doesn't have bleed line ports, unless tha arm is hidin' 'em in tha picture.. tha efi (pump and vst at least) are '94/95 or earlier.. think '96 went to tha pump in tha canister.. there should be a build date stamped somewhere on tha block around tha bend in tha timin' arm... thats only way ya gonna know tha year of tha block.... that may or may not be a serial number stamped in tha flange....tried several combinations and it didn't show on Mercnet.....
    TX......somewhere?
    can't tell if its a 7 petal front either?....are you lookin' at pictures or tha real thing?
    Aug 2006
    St. Louis, MO
    These are pictures he sent me.
    TX......somewhere?
    its been "touched" if it is a PM... some have said they have seen "painted 150, 200, 225 PM's" but I've not... not production anyway.. Block may or may not be '98 but tha rest is questionable.. know tha pump and vst is earlier.. 16 amp stuff also so its had a wrench or two on it....... tha build date is stamped in 1/8" numbers, M/D/YR. somewhere on tha port side, block half. usually at tha base of number two or on tha flange......
    Jul 2002
    FT WORTH, TEXAS
    ive not seen any painted promax unless someone did it, none came from merc painted i think its a pm block it has no bibs, tommy is corecct it has early efi unit which my brand new 95 pmax had, that dont hurt nothing its probably better cuz of the pump deal C4 heads did come on some pmaxs though most have some 789 on um these may be cut since its got 16amp electrics i would not buy it unless i pulled the heads check to see if its 7 petal should be 22 7/16 bolt heads on reed plate (i think)
    Thebes, Il.
    If the motor is local and you like the price, get him to meet you at a shop to have it checked out. For instance across the river in country is Dennis Berry
    Berry Performance Marine Inc5974 Moro Road
    Moro, IL 62067 - View Map
    Phone: (618) 377-4610
    Maybe he could give it inspection. I don't know him just of him and would be from what I hear a reputable guy to give evaluation of its heath and possible build.
    Current-
    '89 Allison XB2002 Comp/Pro Center Steer Maroon on Sandstone
    '98 ProMax 225 JSRE
    20" Mid- Jaco's Ally worked SportMaster 1.87 gears
    Past-
    '96 Allison XB2003 PST White w/ Red Tips accent Stripe
    '89 GT175 w/Bob's Bigfoot LWP
    '97 Cobia 22BR 5.7 MercCrusier/ Bravo
    '85 STV Sprint --2.5 Ported Smiling Jacks Horn EFI system 10k+RPM
    '87 HydroStream V-King YT OMC 235 V6
    '77 Glastron CVX16-- Beaver Tyler built V4 Johnson
    Kona DayCrusier
    17' Contender
    XB03AllyProud on other sites
    Nov 2005
    MAINE
    got a painted 97 hereClick image for larger version.
    Aug 2006
    St. Louis, MO
    I think this is just a bunch of different parts put together. That could be good or bad. He stated it pushed his bass boat 60 mph at 6100 RPM. Seems slow for that engine. I realize there are many factors that affect top speed.
  12. #12
    Aug 2006
    St. Louis, MO
    Quote Originally Posted by redstv169 View Post
    I actually almost bought a 28 skater from Dennis about 15 years ago. He was one heck of a nice guy and seemed like he knows his stuff. This engine is about 6 hours from Dennis's place. I wish I had the money to just have him build me an engine.
  13. #13
    Jul 2002
    FT WORTH, TEXAS
    IM pretty sure it did not come from merc like that i see where bolt heads are painted also on divider plate ive tore down lots of them never ever seen a stock painted one but i have seen yellow ones, red ones, even a purple one once so you know
  14. #14
    Aug 2006
    St. Louis, MO
    Thanks for the help guys. I think I might pass on this one. Seems like someone had a bunch of parts and put together an engine that I am not interested in.
  15. #15
    Some Mercury complete replacement under warranty came painted so did the some 300x for some reason! I have seen 2 personally and the one RussF posted is one of mine. It was opened and rebuilt so I can assure you it is a 225PM in very way.
    If you were given just a block and yes it did not come painted!
    ondtip, like mentioned above all good info, that motor has been into, good or bad who knows. That VST system is from the first gen PM's 95 but if it is working well the motor will never know the difference!
  1. Replies: 9
    Last Post: 08-05-2013, 03:20 PM
  2. Replies: 23
    Last Post: 01-18-2012, 10:13 PM
  3. Mercury Tech: Identifying HP Ratings On Tower Of Power
    By u_got_striped in forum Technical Discussion
    Last Post: 10-01-2009, 08:55 PM
