Results 1 to 2 of 2
Thread: Major Snafu HELP
09-12-2015, 10:20 AM #15000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
Major Snafu HELP
I installed the deck in this Bullet rebuild and decided it would be a good idea to put a layer of CSM on it with polyester. Well some how some way it got water in it coupled with the fact that I used too little resin. Now I have bubbles with moisture under them (non adherence)over at least 1/2 the deck. I'm in the process of grinding out these areas. My question is should I try another layer of CSM or apply a skim coat of thin epoxy putty to seal and smooth? HELP Also posted on BBC
09-12-2015, 11:01 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I would take all the new poly material off. It is compromised. Grind clean, and go with a layer of cloth with epoxy resin. You can squegee the cloth and it will be smoother to start with and easier to finish out with the epoxy filler.
Need major help
By bulldogfiremen in forum Technical DiscussionReplies: 20Last Post: 08-21-2013, 05:17 AM -
Major loss
By skydog in forum The Scream And Fly LoungeReplies: 29Last Post: 01-25-2007, 09:41 PM -
MAJOR ice jam pics
By Riverman in forum The Scream And Fly LoungeReplies: 2Last Post: 04-04-2005, 08:01 PM -
SNAFU - Stockton race date change
By CRyan in forum General Boating DiscussionReplies: 1Last Post: 02-23-2003, 05:17 PM -
OKAY, as the aussies say, SNAFU.
By mr fun in forum General Boating DiscussionReplies: 2Last Post: 12-17-2002, 10:19 PM
