Results 1 to 6 of 6
    Jun 2009
    central minnesota
    Another ? for GM guys
    2005, 1500 5.3gas four door Silverado 4x4 154K. got it @17months/47K..driver seat moves backward when control is pushed forward and forard when moved backward. at 85K- trailer tow button stopped working. now trailer tow lite+ function started to work by itself after 6 years(with tow button I can shut off but not turn on). ever since I got it, when I shut key off and move both front windows DOWN w/driver controls, my seat moves foward and up by itself.stops moving when I move ANY seat control. related issues??? thanx -th
    Louisville, Ky.
    Havin fun with a seat myself. Typical GM stuff.
    Ft. Lauderdale, Fl
    does it have an aftermarket stereo in it?
    Oct 2003
    lake tarpon florida
    memory seat? if so ,the seat module(msm) needs re programming to fix backwards switch issue, their is a bulletin on this. would need to be done at your dealer , sorry.have seen MANY Escalades do this.it may also fix the seat movement when operating windows but there may be a partially grounding circuit in the seat wiring,drivers memory seat has more parts than an automatic transmission! trailer tow switch may be just bad, or a circuit going to it thru the steering column.should be easy to diagnose.
    LTB OLDGUY
  5. Thanks mn808gade thanked for this post
    Since Onboard Diagnostics Second Generation(OBDll) arrived in 1996, its all been about the grounds. Everything goes haywire without good clean contacts/grounds. All (GM)black with white tracers are chassis grounds. All solid blacks are engine charging system related & powertrain grounds. They all have to be perfect.
  7. Thanks mn808gade thanked for this post
    Jun 2009
    central minnesota
    memory seat--yes. THANK YOU-TH
  1. 21/22 SOB Guys...what size wind deflectors you guys using if any???
    By 1deviant in forum General Boating Discussion
    Last Post: 03-19-2014, 07:51 PM
  2. hey guys
    By TheLeprechaun in forum General Boating Discussion
    Last Post: 07-13-2009, 12:49 PM
  3. Hi guys
    By chuckyarus in forum The Scream And Fly Lounge
    Last Post: 05-19-2008, 08:33 PM
