Results 1 to 7 of 7
    Apr 2013
    Lexington, ky
    EGT thermocouple depth on Mercury 2.5 200
    Going to install a set of EGT probes on my 1999 Mercury 2.5 200. I have had the damned things for a year and if I had installed them already then I surely would not have leaned out #4 last Friday...ugh.
    My question is this--> Is there a preferred depth for the tip of the thermocoupling to ensure the most accurate reading? Barely into the stream? Midstream? All the way bottomed out then back it up a 16th?
    What are normal temps while idling, midrange cruising and high rpm running?
    Anything else I should know? I hope to get this done so I don't turn any more pistons to mush once I get it back on the water.
    Slimm
    Dec 2011
    Ludington michigan,on the shore
    Slimm,where are you taking the sample,ex cover(rifle bolts) or ex plate.You want to end up with the tip as close to the center of the stream as possable.
    Apr 2013
    Lexington, ky
    I am using the bottom two bolts on the exhaust divider, rifled bolts. Am I correct in thinking that the temp could vary depending on tip location? Seems the velocity and temperature of the gases close to the block or exhaust cover may be slightly different to heat transfer into the aluminum but I sometimes over think things and try to think outside of my abilities.
    Thanks for the info, and btw I am still waiting for some video of that boat.
    Slimm
    Dec 2011
    The hottest gas will be at the center of the gas stream,try to get the tips there.The exposed tip TC will read the fastest.And it is not uncommon for one side to read 100* or so less than the other.Went to hardy yesterday.Had a great day.Waited for the right time to to turn on the camera,then forgot to do it.To busy havin fun I guess.Try again soon.
  5. Thanks Slimm thanked for this post
    Likes Slimm liked this post
    Apr 2013
    Lexington, ky
    Quote Originally Posted by outasite View Post
    Well at least you had the intention! Thank you again for the info, be safe out there when you get around to the video.
    Slimm
    Dec 2011
    Hoping that maybe someone that was there mite have got a picture or two,I'd like to see it from the other side as well
  8. Likes Slimm liked this post
    Apr 2013
    Lexington, ky
    Just perusing my subscribed posts looking for some part numbers and ran across this thread. Did you ever get some video of that thing or do I need to just take a ride up there and twist yer arm? I have two cameras for boating and my Canon that takes a beautiful video, we could make an event around it!
    Slimm
  1. Thermocouple source... any others?
    By Techno in forum General Boating Discussion
    Last Post: 05-26-2004, 10:50 PM
  2. 2000 225 H.O. Factory Thermocouple???
    By 300Looper in forum Technical Discussion
    Last Post: 03-30-2003, 11:23 PM
