Results 1 to 6 of 6
Thread: stator differences
09-01-2015, 08:32 PM #15000 RPM
- Sep 2009
- iowa
- 674
stator differences
What is the difference between the 1986-87 omc 200 looper stator and the 1988 and up? If I'm not using the quick start, could i still use an early stator on a 1988 and up system?
1975 Hydrostream Ventura II
1987 evinrude 200xp
09-02-2015, 04:47 AM #26000 RPM
- Oct 2003
- LAGRANGE, IL
- 1,277
- 11
- 14
The 86/87 stator part numbers do not supercede up through the same part number chain as the 88 and up stators. These 88 and up engines also have the SLOW system, which may also affect the stator function...
phil blomquist thanked for this post
09-02-2015, 07:51 AM #3Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Yes it will work but you will loose quick start and rpm limiter. 88 is same but gets an extra charge coil to run quick start and limiter. I would not run a stock flywheel above the limiter rpm.
09-02-2015, 08:54 AM #45000 RPM
- Sep 2009
- iowa
- 674
That's what i figured, Racer. I'm not using the quick start anyway. My problem is that it wasn't charging and the tach was going in and out yesterday. I have the regulator/rectifier and stator off my '87 200 that i could use, i just wanted to make sure it would work. I believe my problem is the stator due to some discoloring on the cooper wire. How can i test it with an ohm meter? Is there a test for the regulator?
1987 evinrude 200xp
09-03-2015, 09:36 PM #5
CDI Electronics website has troubleshooting and values to look for. Just do a Google search and you will find all you need in way of troubleshooting. I just went thru the process with a '89 GT175, my problem was timer base-no fire any plug. My Manual is loaned out in another state so google it was and I already knew of CDI and troubleshooting pages. Good luck-check regulator also.
Current-
'89 Allison XB2002 Comp/Pro Center Steer Maroon on Sandstone
'98 ProMax 225 JSRE
20" Mid- Jaco's Ally worked SportMaster 1.87 gears
Past-
'96 Allison XB2003 PST White w/ Red Tips accent Stripe
'89 GT175 w/Bob's Bigfoot LWP
'97 Cobia 22BR 5.7 MercCrusier/ Bravo
'85 STV Sprint --2.5 Ported Smiling Jacks Horn EFI system 10k+RPM
'87 HydroStream V-King YT OMC 235 V6
'77 Glastron CVX16-- Beaver Tyler built V4 Johnson
Kona DayCrusier
17' Contender
XB03AllyProud on other sites
09-03-2015, 09:42 PM #65000 RPM
- Sep 2009
- iowa
- 674
I found the page yesterday, thanks. I replaced both the regulator and the stator with good used parts that i had. Neither one made a difference. I took the power pack off and started checking the output of the stator and it tested good. I also did some tests on the regulator and it passed. I bolted it back together and it started charging. Not sure what i did. I hate when a problem fixes itself, cause i don't know the cause. I'm guessing i have a bad wire or connection somewhere. I've checked everything and found nothing. Oh well. Going to run the river this weekend and keep an eye on it.
1987 evinrude 200xp
Mercury Tech: Help with 245, 260, & 280 differences
By Soddy Creek in forum Technical DiscussionReplies: 4Last Post: 03-29-2013, 07:48 AM -
2.0 hp differences
By fliyingfinn in forum Technical DiscussionReplies: 7Last Post: 03-19-2013, 07:52 AM -
2.5 200 differences????
By cltch in forum Technical DiscussionReplies: 3Last Post: 09-30-2010, 12:26 PM -
differences in 2.4 175 to 200 hp
By 150aintenuff in forum Technical DiscussionReplies: 19Last Post: 06-27-2005, 08:43 PM -
Differences b/t 260 and 280 efi ???
By cuger21 in forum Technical DiscussionReplies: 2Last Post: 01-29-2002, 11:01 PM
