Results 1 to 6 of 6
08-30-2015, 07:59 AM #15000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
What about welding this cavitation plate? photos
I know that skegs are not welded
It looked like welding cavation plates may be acceptable.
Low speed application as long as I own the motor- big boat.
08-30-2015, 08:13 AM #2
I bet that pissed you off.
Weld it, cav plate has little function other than spray diverter in most of it's needs. Meaning it is lightly loaded.
FWIW they are highest loaded at lowest speeds.Regards,
Charlie North
If it ain't broke, modify it.
87 Glastron CVX20 Hull
08-30-2015, 11:47 AM #3
As stated above,but drill the end of that crack,and be prepared for it to break off when you straighten it.Then weld it back on.
08-30-2015, 12:11 PM #4
Drill yes but I would also cut a v groove top and bottom.
RockTeam Junk
08-30-2015, 12:44 PM #5Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
No issues running a welded cavitation plate. Hardly sees any load at all
Erik Kiser
08-30-2015, 06:38 PM #6
Put a Bob's Big Foot on it. Helps planning and adds a bunch of strength. Great on a fishing boat. Not like a "Whale Tail". Mounts under and covers tha whole area, Out of the water at planning speeds anyway.
I carry a gun because a cop won't fit in my pocket.
1987 Glasstream 15V
1986 Mariner "Tower of Power" 115
? About a cavitation plate
By brockshydro in forum Technical DiscussionReplies: 26Last Post: 05-11-2013, 06:08 PM -
Help?!? Cavitation plate went bye bye
By cawhite6814 in forum Technical DiscussionReplies: 29Last Post: 04-21-2009, 04:05 PM -
Cavitation Plate
By MWILLIS in forum Jet Boats, V-Drives and Stern DrivesReplies: 3Last Post: 06-30-2008, 12:02 AM
