Results 1 to 15 of 17
Thread: Plugged pitot
    Feb 2007
    Western Washington State
    Plugged pitot
    After running through some milfoil the pitot in my lower unit that I use with my dash speedo is hopelessly plugged. I have tried compressed air, and I have tried to carefully run a small drill bit by hand into the entrance of the pitot, but nothing I've tried has loosened up the blockage enough. Suggestions?
    Feb 2013
    Pittsbugh
    Buy a new pilot jet. They aren't that expensive. If it's that's jammed up... then you may damage it trying to get it clear "mechanically."
    Personally, I use spray carb cleaner, and compressed air back and forth. Eventually it will soften, and pop out.
    BUT... if the jet is that gummed... then what do the bypass ports in the carb body look like??? If they are plugged... it will fall on it's face when you hit the throttle.
    Quote Originally Posted by Dr Honda View Post
    He is talking speedo pitot. Try blowing from the speedo side.
    Sep 2002
    Soak it for a couple of days in a bucket of water, then run a guitar string through it.
  5. Likes dompie99 liked this post
    Feb 2007
    I've tried blowing through the speedo side with compressed air. Still jammed. Even running it through the water at 70+ mph isn't clearing it. I don't have a bucket big enough to soak it in water for days. Hmm.
    Sep 2002
    I see... You're talking about the integrated pickup in the lower unit.
    Unplug it after a day of boating then... Go to the local music store first, and ask for a .030" guitar string. The outer winding will taper down and end about 6" before the end, leaving a 6" tail of plain steel wire approx. .015". Start with the thin core end, then use the full diameter part to pop the crap out.
    Jun 2009
    central minnesota
    hand held pin vise with small drillbit is the only way I've luck with(carefully)-th
  9. #8
    Feb 2013
    Pittsbugh
    Quote Originally Posted by Dave Strong View Post
    DOh !!!!!! LOL
    Guess I've been in carb mode too long.
  10. #9
    Jul 2010
    The Oldest City
    I gave up on that thing 20 years ago and added a pitot to the transom. Works well and doesn't plug.
    I carry a gun because a cop won't fit in my pocket.
    1987 Glasstream 15V
    1986 Mariner "Tower of Power" 115
  11. #10
    Feb 2007
    Quote Originally Posted by pyro View Post
    Thanks, will give this a try. I have several guitar strings on hand. Guitar is my thang!
  12. #11
    Ft. Lauderdale, Fl
    pressure speedo is so square duuuuude,,,,,, time for a GPS speedo
  13. Likes MegaBaron liked this post
  14. #12
    Feb 2007
    Quote Originally Posted by flabum1017 View Post
    Yeah, yeah; but more $$ than I'm willing/able to pay.
  15. Likes dompie99 liked this post
  16. #13
    Sep 2002
    Save those E and A string tips after you restring. They're great for unplugging super glue tips and such.
  17. #14
    I live in Prineville Oregon which is in the central part of the state
    Pull the lower unit off and go from the top down with a piece of heavy wire and some compressed air. I have cleared many this way.
    Carter
  18. #15
    Feb 2007
    Quote Originally Posted by Carter Powell View Post
    Carter
    I tried that already. No go. I'm worried about perforating the passage that goes through there. How sturdy is it? How aggressive can I be?
  1. Evinrude 4L V-8 ported and plugged
    By williamj in forum Technical Discussion
    Last Post: 08-20-2013, 04:31 PM
  2. OMC Tech: bottom pickups plugged?
    By switzer 140 in forum Technical Discussion
    Last Post: 09-11-2008, 07:09 PM
  3. Early 80's 200 V6 Plugged Tuner
    By tomwinder200 in forum Technical Discussion
    Last Post: 10-02-2007, 02:04 PM
  4. plugged intake holes
    By dschifan in forum Technical Discussion
    Last Post: 05-15-2006, 03:41 PM
  5. plugged water inlet
    By wattalaser2.4 in forum Technical Discussion
    Last Post: 04-24-2002, 08:07 PM
