Results 1 to 15 of 24
Thread: EGT Pyros
    Mar 2011
    Virginia
    EGT Pyros
    What is the best source for EGT Pyro Probes, wiring and Gage for the 2.5L Mercury? Doesn't appear there are many sources other than Livorsi that make probes specific for installation in the back cover of the 2.5L using a rifle bolt. AND if you get Livorsi probes, will they work with a Autometer or Gaffrig meter?
    Go Time
    26 Regulator twin 250 EFI
    Jan 2003
    aalsmeer
    i like these ones
    http://thesensorconnection.com/categ.../multi-channel
    especially the ones with a 0-5 volt output to connect to a logger
    as the original kit also uses K thermo koppels you can hook them right up
    http://www.marineengine.com/parts/me...up-usa/egt-kit
    personally have these! AEM
    <iframe width="853" height="480" src="https://www.youtube.com/embed/DpkBPE53PTk" frameborder="0" allowfullscreen></iframe>
    north louisiana
    Koso makes a nice kit
    Mar 2011
    Virginia
    Thanks Ronnie. I see the probe holder and probes are actually available directly from Mercury. Then I can use any compatible head unit...correct?
    Go Time
    Jan 2003
    aalsmeer
    as long as they specify K thermokoppel for sensor
    WI
    I have an amazing kit from Exhaust Gas Technologies that has a duel digital gauge that is easy to read and blinks red when it surpasses the limit you set on it. I went through a lot of work to have all the exact components in the kit sent out as Hydrodynamics stopped selling their analog kit a while back and this company kinda took over for them, but I could not be happier! I ordered another kit for my buddies boat and just had them copy my last order I made and they sent it right out. Cool ass dudes to work with too.....comes with their best Stinger probes and all the components, bolts, and desired length wires set up JUST for the 2.5 Merc! If this seems interesting to you I could send you some pics as well as a copy of my receipt so they send you EXACTLY what you need.....I do believe the whole kit was under $500 too!
    I have a boat or two.... that I never get to drive
  7. Likes Merc ModVP liked this post
    Aug 2012
    beaumont, tx
    Think I used Hewitt industries...
  9. #8
    Aug 2012
    beaumont, tx
    Good info schrammer...I would of used hydrodynamic s but they already sold business when I was shopping
  10. #9
    Jul 2009
    Crawfordville fl
    bobs machine sales a kit if u want basic
    Nitrous is like a slut. u wanna hit it but you know there will be consequences.
  11. #10
    Mar 2011
    Virginia
    I like the idea of having some programmability in the readout as far as limit indication. Schramer, does the Exh Gas Tech setup use the rifle bolt probe adapter and probe in the bottom bolts of the back cover like the OEM and Livorsi units? PM me some pics of your set up if you would & Exh Gas Tech contact info...Thanks
    Go Time
  12. #11
    Jul 2011
    MN
    Quote Originally Posted by Schramer View Post
    Schramer,
    Can you pm me the component list (or post it here)? I am very interested in this.
    Also, did you get that digital screen? How does it show in full sun?
  13. #12
    WI
    I'm trying to upload pics but photobucket is bein a beeatch....I'll get them up ASAP!
  14. #13
    WI
    Alrighty....heres what i got.....kit comes with everything you see including every nut, ferrell, washer, probe, guage, and any desired extension wire kit you need to get it to the gauge on/near the dash. The numbers are very easy to see in the sun but the high limit red that flashes isn't blatant in DIRECT sunlight but is noticeable in all other conditions....even in direct sunlight you can still see it.
    Call Exhaust Gas Technologies @ 1-800-348-4678 and the guy I spoke with was Rick (extremely helpful and a very nice guy) at extension #304 and have them look up my invoices under Chad Schram......he can send you the duplicate order with whatever length extension wires you want....believe mine were 15' or maybe 20' for my STV. You won't be disappointed and you need nothing else but tools with this kit to have a complete install. Enjoy!!!!
  15. #14
    Jul 2008
    St. Cloud MN
    so i know this is an old post, but i need to do the same. does anyone know exactly what parts are needed (2.5l merc), aside from the 'Koso Kit' that they sell? or anyone have it as one big '2.5 bundle'? thanks all!!
  16. #15
    Jun 2004
    Pelican Lake, WI
    I bought one last year and will never use anything again. The kit I bought has pyro, rpm, and temp. and you can recall highest and set limit that with make screen flash red. I think it was about $500 but cheaper that buy 3 good gauges and no drill big holes in dash. Installation was easy plug and play.
  1. Mercury Tech: pyros temps for 3.0-3.3
    By R.grover in forum Technical Discussion
    Last Post: 09-12-2011, 03:29 PM
  2. Pyros
    By Skirace87 in forum Technical Discussion
    Last Post: 11-17-2007, 08:03 PM
  3. 300x Pyros
    By hendie in forum Technical Discussion
    Last Post: 06-18-2006, 07:09 PM
