Results 1 to 2 of 2
Thread: 03 HPDI 175 bad ecu ?
08-13-2015, 04:05 PM #15000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
Got a customer did a pretty dumb move. Turned his battery switch off while under way. Motor quit and alarm went off. Had to be towed in. I replaced the fuse for the control unit but no start. The fuel pump will not run when keyed, but checks good.The motor will not scan. Can not connect to ecu. The relays seem to be fine. I'm pretty sure the ecu is fried. Any thoughts or opinions greatly appreciated.
08-26-2015, 05:16 PM #25000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
08 hpdi 250
By rickriddle in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 2Last Post: 09-01-2013, 08:57 PM -
Yamaha Tech: Turn My 175 HPDI into a 200 HPDI
By BroCo in forum Technical DiscussionReplies: 0Last Post: 07-27-2009, 01:53 PM -
3.3 hpdi hop-ups
By Red in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 2Last Post: 07-30-2005, 04:32 PM -
Yam 200 Hpdi
By miragemike in forum Technical DiscussionReplies: 6Last Post: 11-27-2001, 12:15 PM
