Results 1 to 15 of 20
    Rhode Island
    Gelcoat OOPS ! ! ! Forgot the MEKP catalyst
    I may or may not have forgotten to add the MEKP catalyst to one shoot while putting gelcoat on my boat...
    The 1st thick layer was fine - 3 x 750mL reloads of the spray gun did the whole boat bottom.
    The start of the 2nd layer (about 30 mins after the 1st was applied) is where I forgot the MEKP. I emptied the 1st 750mL's and said OOOOooo $h1T!!!! Thinking how I can save it - - - I quickly mixed up another batch with about 4-5% MEKP catalyst, and resprayed that entire area.
    WHO KNOWS if this is going to save it or not - - - I may have to wait a couple weeks to find out.
    I then went over the rest of the boat, then finally one last time, another heavy coat with the wax additive to seal it all up.
    DO Y'ALL THINK I'M IN TROUBLE ?!?!?!
    Mar 2009
    Port Saint Lucie
    Fingers crossed, I would have stopped and let what you did kick off cure, then scrape and wipe the uncured gel off and started again. Gel is thick and putting catalyzed gel on top of uncatalyzed gel without it mixing, might not kick off. At worse you'll have to peel the kicked off gel from the uncured gel and redo that area.
    Got mek under it, and mek over it, it will prob get hard. You would be surprised what you can get away with doing gell. Only talking about 20 mils of thickness. Get it warmed up and cure it for a week, start sanding and you will know.
    Ontario, Peterborough
    You should be ok and you did the right fix.
    Polyester gel is like a setup of Domino's.
    To start them falling we add a little hardener.
    The more hardener we add the more points our Domino's will start falling from, the faster they fall.
    If they stop, then a new setup of Domino's tying into the old will get the old setup falling again.
    Epoxy on the other hand is a setup of Domino's laying flat, they can't fall over.
    You stack the proportion on top of each other, say 1 hardener and 3 resin.................
    Then you have to mix all the Domino's up and heat will fuse them together.
    Add more or the wrong proportions will just mess them all up without the proper fusion.
    With a proper fall (Polyester) or mix (Epoxy) you win the game.
    1994 16' Murphy 1991 115 Merc
    1985 12' Charger 1989 70 Merc
    1981 18'DL Charger 1989 200EFI Merc
    Rhode Island
    Let my lapse of thought processes be a lesson to all- yes it worked! As long as you have enough MEK in the under lying, and over lying layers, the gel will harden. I sanded it a bit and it looks great. I can't even put a mark in it with a coin or my fingernail.
    Mar 2009
    Port Saint Lucie
    Awesome, glad it turned out ok.
    You got lucky. The dominoes fell just as described by murph.
    Rhode Island
    The dominoes fell perfectly -
    Attached Thumbnails Attached Thumbnails gelcoat6.jpg   gelcoat5.jpg   gelcoat4.jpg
    Australia
    Happy you got away with that one Your other thread went quiet. Looks like you went no wax except for the final coat?
    Rhode Island
    Quote Originally Posted by GregAdams View Post
    Bingo - couple layers of no wax - then final layer with wax. Worked perfect. About an hour of set time inbetween coats. (except for the one batch I forgot the MEK, I immediately went back over that).
    The final layer will be with the duratec additive after I sand this orange peel down smooth. The stuff sprays like truck bed liner -
    The other thread I'm keeping for the regular progress updates. That'll be the full start to finish thread lol. I deviate when I need technical advice like this.
    I thinned the gelcoat about 8% with styrene thinner, and used a spray gun from harbor freight with a 2mm tip.
    http://www.harborfreight.com/33-oz-l...gun-61455.html
    SHHHH! Truck bed liner is a secret speed coating.....
    Australia
    I used it in the back of my truck and it didn't go any faster...
  13. Likes Slimm liked this post
  14. #13
    Try it going backwards, big difference.
    Australia
    I never thought of that ... lol
  16. #15
    Sep 2011
    Deplorableville
    Good job man. I don't envy you at all at this point, I did all of my wet sanding, buffing and polishing last year at this time. The prep work and spraying is the east part.
  1. Oops the Fl cops forgot
    By BUSHWACKER in forum The Scream And Fly Lounge
    Last Post: 06-05-2011, 11:25 PM
  2. Duratec Catalyst
    By gstorr in forum Fiberglass and Composites Discussion
    Last Post: 04-25-2009, 08:10 PM
  3. How do you make Gelcoat-filler out of gelcoat?
    By Hydro-T20 in forum Fiberglass and Composites Discussion
    Last Post: 05-18-2007, 08:00 PM
  4. what catalyst?
    By spanky2002 in forum Fiberglass and Composites Discussion
    Last Post: 03-18-2004, 11:00 AM
  5. I forgot!
    By jmr112 in forum Technical Discussion
    Last Post: 03-16-2004, 08:00 PM
