Results 1 to 3 of 3
07-31-2015, 03:39 AM #1
Aftermarket fuel pressure regulator
I am going to run an Aeromotive fuel pump and regulator does anyone have ny ideas, drawings or pictures of any brackets that they made for there reguator that they would be be willing to share ??? thanks James
07-31-2015, 05:41 AM #2
laser motor??
heres mine using an aeromotive a1000 regulator...
i used the bracket it came with and one of the diaphragm pump mounting holes....i flipped the bracket on the regulator and i think (cant remember) i drilled and tapped the mounting holes to use a #10 allen bolt.81' HYDROSTREAM VECTOR / slightly Modified 200
08-01-2015, 05:46 AM #3Bud Conner "Heathen" "Defending Our Constitution"
Mercury Tech: Where can I find a aftermarket 39 PSI 260 type fuel pressure regulator?
By Hank W in forum Technical DiscussionReplies: 13Last Post: 11-09-2011, 10:39 PM -
Do I need to run a fuel pressure regulator with a Holley Red fuel pump?
By Steve2ManyBoats in forum Technical DiscussionReplies: 14Last Post: 03-31-2011, 08:09 AM -
Recommended inline fuel filter and fuel pressure regulator
By topkick in forum Technical DiscussionReplies: 2Last Post: 09-20-2005, 09:25 AM -
Do you think my fuel pressure regulator is bad?
By BLUElixir in forum Technical DiscussionReplies: 3Last Post: 09-16-2003, 08:56 PM
