Results 1 to 14 of 14
    Jul 2015
    Rhode Island
    Need more power 225 3.0L carb
    Looking to get another 30+ hp be ideal. 95 3.0L carb 225 off shore series.
    Im wondering how much I can cut the heads. Or what cc factory is I run 93 octane in it now but if I need to run 108 race gas I'll do it
    planning on putting a exhaust tuner on it and rejet the carbs and possibly a 300 pro max ignition module.
    Tha ks for the help in advance.
    82 enchanter 225 3.0l merc 70+ Sold
    81 Baja 16ss. 140 Suzuki 52.sold
    86 Stephen stepp velocity 3.0L merc. #737
    Jun 2011
    phoenix
    Unless this is a drag race/ grudge race boat, I wouldn't do mods that require full race fuel. That sounds like it would be quite expensive to use a lot. Your goals.should be achievable with premium pump gas
    Jul 2015
    Rhode Island
    Ok so keep compression under 160psi then.
    And what cc are factory heads and what should I cut them too
    Jun 2011
    phoenix
    Contact Jay Smith Racing Engines. He cuts alot of heads on these motors. He will be able to point you in the right direction
    Jul 2010
    Miami Springs, FL
    Quote Originally Posted by Baderic03 View Post
    For 93 oct gas you need to keep the comp under 150 psi. About 145 PSI preferably as a small buffer in case you got a bad batch of gas, etc.
    1989 Hydrostream HST
    1989 Actioncraft Flatsmaster SE
    2006 Baycraft
    Jul 2015
    Rhode Island
    I'm going to run 104 in the motor to be safe. I wanna run like 150-160psi. And anyone have the number for jay smith racing.
    Jul 2010
    Miami Springs, FL
    2006 Baycraft
    Jul 2015
    Rhode Island
    That was my old boat. Sold the crack mate hull and now motor is on my 22 steve stepp velocity hull
    Jul 2010
    Miami Springs, FL
    You might want to note what you would like to get out of this boat/engine combo rather than just horsepower on the engine. Say, if you want to get a certain speed then list engine, mods, setup and hull. That way others can give you all kind of info to achieve your boat goals. Some engine and setup mods might be a lot easier and cheaper than going with am engine that requires race fuel.
    2006 Baycraft
    Jul 2015
    Rhode Island
    This is a simple question asked. I want 30+ hp. On my motor.
    Jul 2010
    Miami Springs, FL
    Figured you say that.
    2006 Baycraft
  12. #12
    Jul 2015
    Rhode Island
    Boat is setup fine. I just want more power.
  13. #13
    Jul 2015
    Rhode Island
    Boat runs mid 70s now. It's a class 7 opa boat so I just want more raw power for turns and if I need to back out that I have the power to get there quicker to 60mph.
  14. #14
    Nov 2005
    Plaisance, Québec, Canada
    now correct me if i am wrong but 3.0L 225 hp's are '' O'rings '' heads I bought 300X heads instead of shaving the heads
    Now I am in the process of adjusting the jetting on those carbs....they were .074 almost all around now I made them .076'' an increase of ..002''
    will see this week-end if God is great with me.
    Glastron GT 150 W OMC 140
    Glastron GT150 w OMC 235
    Hydrostream Vision with 2.0l 135
    Hydrostream HST w 3.0L 225
    I know two things that are infinite, the Universe and Human's Stupidity, although I am not sure about the first one.
  1. carb change or worked??reeds?More power on 2.4
    By Bigjohnsons in forum Technical Discussion
    Last Post: 01-19-2007, 08:49 AM
  2. Intermittent power loss '89 2.4 carb
    By B.Mac in forum Technical Discussion
    Last Post: 07-07-2002, 06:56 AM
